[mapserver-users] Upgrading Apache and PHP that came with MS4W
EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE james.evans.4 at us.af.mil
Mon Apr 14 10:07:44 PDT 2014
Our servers already had IIS running, and I would have to justify running Apache under our new accreditation.  I probably would prefer to go with Apache, but it was easier to go with IIS.
James
-----Original Message-----
Sent: Monday, April 14, 2014 11:03 AM
To: EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] Upgrading Apache and PHP that came with MS4W
Hi James,
Thanks for your reply. Why did you choose to migrate from MS4W to IIS + GisInternals build, and not to Apache + GisInternals builds?
Are you using PHP/MapScript?
Thomas
From: "EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE" <james.evans.4 at us.af.mil>
To: tr <traffin at sirap.fr>, "mapserver-users at lists.osgeo.org"
<mapserver-users at lists.osgeo.org>
Date: Sun, 13 Apr 2014 15:07:33 +0000
> Hi Thomas,
> I was forced to remove MS4W from our servers due to security
> vulnerabilities in Apache and PHP.  I was able to get the GISInternals
> build working under IIS 7.  It required a little more effort to get
> going, but so far it seems to be working.  Here are the steps I had to
> follow to get it going:
> Turn on IIS6 Compatibility Mode
> Turn on CGI and ASP.Net in IIS
> Edit ISAPI and CGI Restrictions
>     Check the box to allow Unspecified CGI Modules and to allow
> Unspecified ISAPI modules Look in the binary zip file and copy the
> following dlls to the Mapserver directory
>    Hdf5.dll
>    Hdf5_hl.dll
>    Hdfdll.dll
>    Geos.dll
>    Szip.dll
>    Openjp2.dll
> Then, I had to add this to my map file:
>    CONFIG PROJ_LIB "C:\Program Files\MapServer\projlib"
>    CONFIG GDAL_DATA "C:\Program Files\MapServer\gdal-data"
> Or you could just set environment variables for each.
> I also had to download and install PHP, and the Microsoft URL Rewrite
> module for IIS7.  After that, I seem to be back to the same capability
> I had previously.
> James
> ________________________________________
> From: mapserver-users-bounces at lists.osgeo.org
> [mapserver-users-bounces at lists.osgeo.org] on behalf of tr
> [traffin at sirap.fr]
> Sent: Friday, April 11, 2014 4:53 AM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] Upgrading Apache and PHP that came with
> MS4W
> Hi Jeff,
> As each MS4W user I'm very interested by upgrading my install.
> Have you got any news, please? (Maybe an ETA?)
> Does the community edition will contain PHP Mapscript?
> Are there official or public informations about custom builds
> conditions please (I don't have response by contacting you or your
> organization directly)?
> Thanks for your work and the informations to come.
> Thomas
