[mapserver-users] This seems like a dumb question, how do I convert ST_EXTENT (POSTGIS) results back into a Geometry for Mapsever?
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Mon Aug 11 10:49:17 PDT 2014
Racked my brain on this last Friday, couldn't get anything to work from a Mapserver Mapfile.
I can get the numbers from POSTGIS just fine via PGADMIN, but they come back as a BOX entity which MapServer doesn't seem to know what to do with.   I tried casting but got no matching records.
MAPFILE fragment . . .
DATA "the_geom from (
                        select
                                st_extent(sub1.the_geom)::geometry as the_geom
                        from
                                loc_last as sub1
                        where
                                vname in (%asset_id%)  -- vname in ('2293','2297')
                        ) as subquery using unique the_geom using srid=200068"
In pgadmin, the above select returns polygon (per st_astext applied)  The subselect is grabbing a couple of points based on asset_id(s).
Thanks
bobb
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140811/7b290c7a/attachment.html>
