[mapserver-users] Bulk creation of mapfile
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Aug 13 14:50:21 PDT 2014
I believe the PropertyShark team stores the layers in a mysql database,
if I remember their presentation (but I'd rather use postgres and
plpgsql functions as well, nice Cristiano).
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2014-08-13 3:44 PM, Cristiano Sumariva wrote:
> I took the plpgsql way. Created a set of functions that generates the
> mapfile blocks and store the tokens in several postgresql tables(using
> traditional SQL relations).
> Then I invoke the mapfile( id ) from database and pass the mapfile text
> direct to mapscript.
> With this, the mapfile creation has been managed by the database and did
> not need any files.
> Since all layers are already at database, I do not think those
> generation steps take some much processing.
> It is working for a few layers already loaded.
> Current postgresql could also store them as XML. Recent mapserver could
> parse xml mapfiles. But never implemented something this way.
> 2014-08-13 15:08 GMT-03:00 Alex Lopes <alexlopespereira at gmail.com
> <mailto:alexlopespereira at gmail.com>>:
> Thank you everybody who helped me. I'll study all the suggestions
> and post here the complete source code of my solution.
> Alex
> 2014-08-13 9:34 GMT-04:00 Jeff McKenna
> <jmckenna at gatewaygeomatics.com <mailto:jmckenna at gatewaygeomatics.com>>:
> Definitely leverage mapfile INCLUDEs
> (http://mapserver.org/mapfile/__include.html
> <http://mapserver.org/mapfile/include.html>). In your case, each
> LAYER could be an include, and you could have a mapfile template
> file that your shell script writes those include layers into.
> I recently saw a presentation at FOSS4G-Europe from
> PropertyShark, who manages thousands of layers, using includes,
> and generates them through custom Perl scripts (you can read
> about that discussion, or contact them, through the recent
> Google+ discussion
> https://plus.google.com/__communities/__103841604654304099367
> <https://plus.google.com/communities/103841604654304099367>).
> -jeff
> Jeff McKenna
> http://www.gatewaygeomatics.__com/
> <http://www.gatewaygeomatics.com/>
> On 2014-08-13 10:03 AM, Alex Lopes wrote:
> Hi Everybody,
> I need to create a script shell to build thousands of
> mapfiles based on
> postgis layers.
> Which is the best way to accomplish this task?
> Best regards,
> Alex
