[mapserver-users] Multiline string error
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Wed Aug 13 23:38:56 PDT 2014
I would put this into MAP level
CONFIG "CPL_DEBUG" "ON"
and then at layer level
DEBUG 5
-Jukka Rahkonen-
Ian Walberg wrote:
> Steve,
> We will add some debug to the OGR read later today or tomorrow.
> How do I turn on the maximum debug?
> Thanks
> Ian
> -----Original Message-----
> From: Ian Walberg
> Sent: Wednesday, August 13, 2014 3:20 PM
> To: 'Lime, Steve D (MNIT)'; mapserver-users at lists.osgeo.org; mapserver-
> dev at lists.osgeo.org
> Subject: RE: Multiline string error
> Steve,
> OGR connection to SQLITE DB.
> Regards
> Ian
> From: Lime, Steve D (MNIT) [mailto:Steve.Lime at state.mn.us]
> Sent: Wednesday, August 13, 2014 8:46 AM
> To: Ian Walberg; mapserver-users at lists.osgeo.org; mapserver-
> How are you submitting the WKT to MapServer? Is it via MapScript, via inline
> features or some other mechanism?
> Steve
> From: mapserver-dev-bounces at lists.osgeo.org [mailto:mapserver-dev-
> bounces at lists.osgeo.org] On Behalf Of Ian Walberg
> Sent: Wednesday, August 13, 2014 10:01 AM
> To: mapserver-users at lists.osgeo.org; mapserver-dev at lists.osgeo.org
> Subject: Re: [mapserver-dev] Multiline string error
> Devs,
> The MULTILINE string below gives the following in mapprimitive.c and then as
> the first shape has 0 points the msSmallMalloc fails as the size passed to it is -8.
> [Wed Aug 13 07:55:10 2014].618971 Shape contains 2 parts.
> [Wed Aug 13 07:55:10 2014].618987 Part 0 contains 0 points.
> [Wed Aug 13 07:55:10 2014].619001 Part 1 contains 3 points.
> [Wed Aug 13 07:55:10 2014].619016 0: (882.383078, 511.333078)
> [Wed Aug 13 07:55:10 2014].619032 1: (825.909890, 260.048026)
> [Wed Aug 13 07:55:10 2014].619049 2: (882.383078, 511.333078)
> Any clues what we should look at next?
> This same source data file and layer work with older versions of mapserver 6.
> Thanks
> Ian
> From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-
> Sent: Monday, August 11, 2014 3:53 PM
> Subject: [mapserver-users] Multiline string error
> Folks,
> With Mapserver 6.5-dev from git and GDAL 1.9.1 the line below either does not
> draw or causes mapserv to error and not render an image without an error
> message.
> MULTILINESTRING ((-110.220980 38.982832, -110.220887 38.982863, -
> 110.221614 38.982708, -110.220980 38.982832),(-110.220980 38.982832, -
> 110.220887 38.982863, -110.221614 38.982708, -110.220980 38.982832))
> Changing the final digit on either of the first or last lats/longs and it draws ok!
> Any ideas?
> Thanks
> Ian
> mapserver-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/mapserver-dev
