[mapserver-users] Interface between QGIS2.4 and MapServer
TC Haddad tchaddad at gmail.com
Wed Dec 10 17:54:21 PST 2014
I can confirm that the plugin works with QGIS 2.4 at least, and it is
available under "experimental plugins". It is very handy for quickly
generating nicely classed data.
Regarding Jukka's comment, I personally always chose the option "export
layers only" and I find with that option, the results are more like 95%
correct map files - I just need to include those exported layer definitions
in a skeleton map file that already contains my relevant map and web
metadata information.
Tanya
On Wed, Dec 10, 2014 at 8:55 AM, Rahkonen Jukka (Tike) <
jukka.rahkonen at mmmtike.fi> wrote:
>  Hi,
>  I believe you can install the plugin still from the experimental QGIS
> plugins. At least I seem to have it installed on QGIS 2.0.1.
>  I warn you that the plugin creates mapfiles which are about 80% correct.
> For fixing them to work properly you should know relatively well how to
> write good mapfiles by hand.
>  -Jukka Rahkonen-
>  Maiorano Pasquale wrote:
> Dear Sirs,
> I am trying to export my QGIS project to MapServer without success. I
> found several tutorials on Youtube that speak about a pluging named *RT
> Mapserver Export* . It seam does not exist anymore. Can You help me
> giving some advice in how to export my project in order to expose it on the
> WEB via Mapserver?
> The mentioned plugin seems disappeared starting from the QGIS version 1.8
> on.
> Please take into account that my job is locked due to this issue. Many
> thanks in advance.
> Pasquale Maiorano
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141210/60e81b4f/attachment.html>
