[mapserver-users] browse mode no longer saves images?
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Wed Dec 17 08:22:38 PST 2014
I'm able to save images using 6.4.1. Just tested it with a template that uses [img] and [ref]... This is on a Linux server. --Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of geographika
Sent: Wednesday, December 17, 2014 6:08 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] browse mode no longer saves images?
Hello again,
A few more tests with no luck in saving the images to disk on the server.
Does anyone save images to the server using 6.4? It works fine on the examples at http://demo.mapserver.org/cgi-bin/mapserv? but these use MapServer 5.6.5
This applies to [img], [scalebar], [legend] even though unique filenames are generated in the template output e.g.
<img src="/tmp/PMS1418817695480.png">
<img src="/tmp/PMSsb1418817695480.png">
<img src="/tmp/PMSleg1418817695480.png">
I've tried running from the command line to rule out the web server:
mapserv -nh "QUERY_STRING=map=C:/MapServer/apps/pms/mymap.map&LAYERS=Test&mode=browse"
I also tried to create a new OUTPUTFORMAT to use, setting it explicitly to use the filesystem (although I'm not sure if this only applies to OGR formats):
OUTPUTFORMAT
NAME 'png2'
DRIVER "GDAL/PNG"
MIMETYPE "image/png"
EXTENSION "png"
IMAGEMODE RGBA #All features are rendered against an initially transparent background.
FORMATOPTION "STORAGE=filesystem"
END
And then from the command line:
mapserv -nh "QUERY_STRING=map=C:/MapServer/apps/pms/mymap.map&LAYERS=Bridges&mode=browse&QFORMAT=png2&SAVEQUERY=true"
The logs show the following (with debug set to 5) with no errors:
[Wed Dec 17 11:55:42 2014].367000 CGI Request 1 on process 2272
[Wed Dec 17 11:55:42 2014].382000 mapserv request processing time (msLoadMap not incl.): 0.015s
[Wed Dec 17 11:55:42 2014].382000 msFreeMap(): freeing map at 0000000002A3A870
Regards,
Seth
On 16/12/2014 14:28, Jörg Thomsen wrote:
Hi Seth,
are you very sure the path C:/Mapserver/apps/pms/tmp exists? Please
check. Also you can use debug-mode to see where mapserver wants to write
the image and perhaps cannot.
the directory has to be writable, but with windows this should not be a
problem.
And you have to define the alias in apache for the tmp-directory like
ALIAS /tmp C:/Mapserver/apps/pms/tmp
<Directory C:/Mapserver/apps/pms/tmp>
</Directory>
Jörg
Am 16.12.2014 um 14:03 schrieb geographika:
Hi list,
Until now I have been using MapServer as a WMS server. I've only
recently been trying out the CGI controls, which would be very handy for
a reporting application.
The MapServer tutorials refer several times to saving temporary images
using the mode=browse. At
http://demo.mapserver.org/tutorial/section3.html the map images
generated in these tutorials refer to image files on the web server (so
are not generated dynamically). E.g.
http://demo.mapserver.org/ms_tmp/EX1.9_141873269321745.png
I've tried to set this up in MapServer 6.4 without success. I've set up
parameters in the WEB section as follows:
WEB
IMAGEPATH "C:/Mapserver/apps/pms/tmp"
# Also tried "tmp/"
IMAGEURL "tmp/"
TEMPLATE "reports/test.html"
However no images are ever created in this folder when using a request
such as http://localhost/mapserver/?LAYERS=mylayer&mode=browse
<https://localhost/mapserver/?LAYERS=mylayer&mode=browse><https://localhost/mapserver/?LAYERS=mylayer&mode=browse>
The template contains file names such as tmp/MyMap14187343292752.png but
these never seem to be written to disk. How can these images be persisted?
I know I could use mode=map to generate an image, but I want to create
legends etc. all with a single request.
Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141217/9bb4645a/attachment.html>
