[mapserver-users] is there a way to avoid clipping the symbols on the edge of a tile
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Fri Dec 19 07:32:30 PST 2014
You’re not using mode=tile? The regular CGI map (e.g. mode=map) creation knows nothing about tiles so there’s no way to avoid edge effects. There are specialized tools like MapCache that take MapServer maps and create tiles from them. Those tools use techniques like meta-tiling, no label buffers and map edge buffers to avoid edge effects. MapServer also has a built-in tile mode (mode=tile) that can do edge buffering but you’re limited to (I think) known tiling schemes (like Google Maps).
Steve
Sent: Thursday, December 18, 2014 8:47 PM
To: Lime, Steve D (MNIT)
Subject: RE: [mapserver-users] is there a way to avoid clipping the symbols on the edge of a tile
I create tiles use mapserver and layer.map
like this /cgi-bin/mapserver?map=/var/www/wms/layer.map.
> From: Steve.Lime at state.mn.us<mailto:Steve.Lime at state.mn.us>
> To: liuxiaoer at live.cn<mailto:liuxiaoer at live.cn>
> Date: Fri, 19 Dec 2014 02:43:01 +0000
> How are you creating the tiles?
> ________________________________________
> From: 刘小二 [liuxiaoer at live.cn]
> Sent: Thursday, December 18, 2014 8:23 PM
> Hi,Steve
> thank you again for your answer.
> But it don't work. The problem is still exists.
> What should I do to solve this question?
> This is my Mapfile below.
> MAP
> NAME "map"
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> METADATA
> wms_enable_request "*"
> wms_srs "EPSG:4326 EPSG:900913"
> labelcache_map_edge_buffer "10"
> tile_map_edge_buffer "10"
> END
> END
> SYMBOL
> NAME 'hospital'
> TYPE pixmap
> IMAGE '/mnt/mapserver/img/hospital.png'
> END
> LAYER
> NAME Layer_1400668502611
> TYPE point
> data '/mnt/mapserver/vector/Layer_1400668502611.shp'
> CLASS
> STYLE
> SYMBOL 'hospital'
> SIZE 15
> END
> END
> END
> END
> I shall appreciate a reply from you in regard to my question.
> Thanks.
> liuxiaoer
> To: liuxiaoer at live.cn<mailto:liuxiaoer at live.cn>; mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
> Date: Thu, 18 Dec 2014 22:40:50 +0000
> Check out the "labelcache_map_edge_buffer" and “tile_map_edge_buffer” metadata settings (in the WEB metadata section), or using metatiles. It depends on how you’re generating tiles (mode=tile or MapCache/TileCache).
> Steve
> From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of ???
> Sent: Wednesday, December 17, 2014 3:18 AM
> To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
> Subject: [mapserver-users] is there a way to avoid clipping the symbols on the edge of a tile
> Hi, is there a way to avoid clipping the symbols on the edge of a tile, so all symbols would be fully displayed?
> [cid:image001.png at 01D01AE1.60C6A7E0]
> The second house symbol is clipped.
> Thank you very much!
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141219/b0d0988f/attachment-0001.html>
