[mapserver-users] Mapserver as WFS 1.1.0 client
Lars Fricke lars.fricke at skendata.de
Tue Dec 23 09:15:10 PST 2014
Well at least now I know.
Thanks for both of your effort.
Cheers and blessed Christmas.
Lars
Based on other input from Daniel Morissette I think it's pretty safe to
say that MapServer only supports WFS layers with versions 0.0.14 and
1.0.0. Sorry... I don't know what it would take to extend things to
1.1.0 though (patches welcome). Steve -----Original Message----- From:
Lars Fricke [mailto:lars.fricke at skendata.de] Sent: Tuesday, December 23,
2014 10:58 AM To: Lime, Steve D (MNIT); mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Mapserver as WFS 1.1.0 client Hello
Steve, Thank you for your answer. I tried setting to GET and this is
what i got: "<ows:Exception exceptionCode="NoApplicableCode"
locator="mapserv"><ows:ExceptionText>msWFSGetFeature(): WFS server
error. ms_error->code not found msWFSLayerWhichShapes(): WFS connection
error. WFS request produced unexpected output (junk?) for layer
HK.</ows:ExceptionText></ows:Exception>" The message about the wrong
version is not showing up. Maybe I'm doing something wrong? Here's my
layer definition: "LAYER NAME "HK" TYPE Point UNITS METERS CONNECTION
"http://localhost:8081/geoserver/wfs?" CONNECTIONTYPE WFS #EXTENT 618740
5962679 1737924 7376186 does not seem to matter STATUS ON METADATA
"wfs_version" "1.1.0" "wfs_title" "HK" "wfs_connectiontimeout" "60"
"wfs_typename" "Data:HK" "wfs_maxfeatures" "500" "wfs_request_method"
"GET" "gml_include_items" "all" "wfs_title" "HK" "wfs_srs" "EPSG:3857"
"gml_featureid" "GCOA_ID" "wfs_enable_request" "*" END # METADATA
PROJECTION "init=epsg:3857" END # PROJECTION CLASS NAME "Koordinaten"
STYLE COLOR 190 87 66 OUTLINECOLOR 255 0 0 SIZE 4 SYMBOL "circle_filled"
END # STYLE END # CLASS END # LAYER" The request is:
"http://localhost:8082/wfs?SERVICE=WFS&VERSION=1.1.0&&request=GetFeature&TYPENAME=HK&local&SRS=EPSG:3857&bbox=793732,6570204,793765,6570228"
Thank you Cheers Lars Am 22.12.2014 um 16:09 schrieb Lime, Steve D (MNIT):
>> Looking at the mapwfslayer.c code it's a little confusing. I see references to 0.0.14 and 1.0.0 for POST requests and 0.0.14, 1.0.0 and 1.1 for GET requests.  You can try setting:
>>     "wfs_request_method"   "GET"
>> In the layer metadata and see if that works for you.
>> Steve
>> From: mapserver-users-bounces at lists.osgeo.org
>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Lars
>> Fricke
>> Sent: Monday, December 22, 2014 12:58 AM
>> To: mapserver-users at lists.osgeo.org
>> Hello List,
>> can you please give me a quick feedback on which version WFS MapServer supports as CLIENT (see below)? I can't really find it in the docs.
>> Thank you.
>> Lars Fricke
>> Am 18.12.2014 um 08:29 schrieb Lars Fricke:
>>> Hello,
>>> I am trying to access an external WFS with MapServer as client to
>>> cascade it. I get the following error message:
>>> msBuildWFSLayerPostRequest(): WFS connection error. MapServer
>>> supports only WFS 1.0.0 or 0.0.14 (please verify the version metadata
>>> wfs_version).
>>> Indeed the external server only sends version 1.1.0 and my mapfile has:
>>> METADATA
>>> Now when I search on the net, I find bug reports about WMS 1.1.0 and
>>> MapServer but no information if I can use it as a 1.1.0 client at all.
>>> And if so, do I need to use something specific to activate it?
>>> I'm on a German Ubuntu 14.04 64bit with Apache2 and mapserv -v says:
>>> MapServer version 6.4.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML
>>> SUPPORTS=PROJ SUPPORTS=GD SUPPORTS=AGG SUPPORTS=FREETYPE
>>> SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS SUPPORTS=RSVG SUPPORTS=ICONV
>>> SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>>> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
>>> INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>> Thanks for looking into this.
>>> Best
>>> Lars
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
