[mapserver-users] Mapcache
TDS
tds at tds-net.de
Sat Feb 1 10:47:06 PST 2014
Sorry for my late answer.
The problem is that some WMS aren't configured correctly. Some of them
use e.g. EPSG:31466 or 67 or 68 for displaying whole germany. And that's
false. My client restricts the extents to defaults but show whole map
(MapServer is displaying right exceed limits).
So...
a) Where can I calculate world extents for SRS which have smaller
default extents like the one above (e.g. 31466 extents should expand to
whole world)?
or
b) How can I get MapCache to act like MapServer and displaying tiles
outside default extents?
MfG M. Martin
mailto:tds at tds-net.de
1+1=10
You have a question? - 42 or RTFM.
Am 29.01.2014 14:55, schrieb Thomas Bonfort:
> I'm sorry, I don't really understand your question... mapcache splits
> the area given in your grid extent into square tiles of the given
> resolutions, and asks the wms to render them. Areas outside the grid
> extent will not be stored. Any "distortion" is not created by mapcache,
> who is only requesting images to the wms with the extents/srs of each
> individual tile.
> thomas
> On 29/01/2014 14:44, TDS wrote:
>> Hello,
>> e.g. the extents for 25XXX and 31XXX are restricted. Outside of this
>> area, even if it is a little piece of it, it is not drawn.
>> And the resolutions will make a distorted image (OpenLayers, QuantumGIS,
>> etc.). In real WMS from mapserv there is no problem if outside extents
>> or with zoom levels.
>> What I need is:
>> a) Draw grid with given SRS even it doesn't fit in area.
>> b) What are the resolutions for these SRS (maybe world wide)?
>> I've read that e.g. mapserv calculate resolutions itself, but mapcache
>> do. Where can i get or calculate these resolutions?
>> MfG M. Martin
>> 1+1=10
>> Am 29.01.2014 14:33, schrieb Thomas Bonfort:
>>> Please be a bit more specific as to what "aren't working" means
>>> thomas
>>> On 29/01/2014 09:07, TDS wrote:
>>>> Hello,
>>>> I have some problems with MapCache projections and grids. First my XML:
>>>> <?xml version="1.0" encoding="UTF-8"?>
>>>> <mapcache>
>>>> <grid name="EPSG25831">
>>>> <metadata>
>>>> <title>ETRS89 / UTM zone 31N</title>
>>>> </metadata>
>>>> <title>OSM Tile Cache Service</title>
>>>> <srs>EPSG:25831</srs>
>>>> <extent>238379.2278 4265559.3497 761620.7722
>>>> 6914547.3835</extent>
>>>> <size>256 256</size>
>>>> <units>m</units>
>>>> <resolutions>
>>>> 2183915.093862179 1091957.546931089 545978.7734655447 272989.3867327723
>>>> 136494.6933663862 68247.34668319309
>>>> 34123.67334159654 17061.83667079827 8530.918335399136 4265.459167699568
>>>> 2132.729583849784 1066.364791924892
>>>> </resolutions>
>>>> </grid>
>>>> <grid name="EPSG25832">
>>>> <metadata>
>>>> <title>ETRS89 / UTM zone 32N</title>
>>>> </metadata>
>>>> <srs>EPSG:25832</srs>
>>>> <extent>265948.8191 6421521.2254 677786.3629
>>>> 7288831.7014</extent>
>>>> <units>m</units>
>>>> <resolutions>
>>>> </resolutions>
>>>> </grid>
>>>> <grid name="EPSG25833">
>>>> <metadata>
>>>> <title>ETRS89 / UTM zone 33N</title>
>>>> </metadata>
>>>> <srs>EPSG:25833</srs>
>>>> <extent>227879.8880 3932632.6543 1044484.3835
>>>> 8893131.0281</extent>
>>>> <units>m</units>
>>>> <resolutions>
>>>> </resolutions>
>>>> </grid>
>>>> <grid name="EPSG31466">
>>>> <metadata>
>>>> <title>DHDN / 3-degree Gauss-Kruger zone
>>>> 2</title>
>>>> </metadata>
>>>> <srs>EPSG:31466</srs>
>>>> <extent>2490547.1867 5440321.7879 2609576.6008
>>>> 5958700.0208</extent>
>>>> <units>m</units>
>>>> <resolutions>
>>>> </resolutions>
>>>> </grid>
>>>> <grid name="EPSG31467">
>>>> <metadata>
>>>> 3</title>
>>>> </metadata>
>>>> <srs>EPSG:31467</srs>
>>>> <extent>3386564.9400 5237917.9109 3613579.2251
>>>> 6104500.7393</extent>
>>>> <units>m</units>
>>>> <resolutions>
>>>> </resolutions>
>>>> </grid>
>>>> <grid name="EPSG31468">
>>>> <metadata>
>>>> 4</title>
>>>> </metadata>
>>>> <srs>EPSG:31468</srs>
>>>> <extent>4386596.4101 5237914.5325 4613610.5843
>>>> 6104496.9694</extent>
>>>> <units>m</units>
>>>> <resolutions>
>>>> </resolutions>
>>>> </grid>
>>>> <grid name="EPSG31469">
>>>> <metadata>
>>>> 5</title>
>>>> </metadata>
>>>> <srs>EPSG:31469</srs>
>>>> <extent>5386627.6162 5237909.9506 5613641.6401
>>>> 6104491.8566</extent>
>>>> <units>m</units>
>>>> <resolutions>
>>>> </resolutions>
>>>> </grid>
>>>> </mapcache>
>>>> Resolutions for "g" are: 156543.0339280410 78271.51696402048
>>>> 39135.75848201023 19567.87924100512 9783.939620502561 4891.969810251280
>>>> 2445.984905125640 1222.992452562820 611.4962262814100 305.7481131407048
>>>> 152.8740565703525 76.43702828517624 38.21851414258813 19.10925707129406
>>>> 9.554628535647032 4.777314267823516 2.388657133911758 1.194328566955879
>>>> 0.5971642834779395
>>>> So what are the resolutions for other grids? Mine aren't working (maybe
>>>> of combination resolutions and extents?) :-(
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140201/15b676ec/attachment-0001.html>
