[mapserver-users] MapServer should not collapse geometries in same layer class
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Fri Feb 7 10:56:51 PST 2014
I made a quick test.
SYMBOL
NAME "arrow-end"
TYPE vector
FILLED true
POINTS
0 0.4
3 0.4
3 0
5 0.8
3 1.6
3 1.2
0 1.2
0 0.4
END # POINTS
ANCHORPOINT 1 0.5
END # SYMBOL
CLASSITEM 'area'
CLASS
NAME "0,5 - 5 ha"
EXPRESSION ([area]>=0.5 AND [area]<5)
STYLE #outer black
WIDTH 16
COLOR 0 0 0
LINEJOIN NONE
END
STYLE #inner blue
WIDTH 12
COLOR 85 170 255
LINEJOIN NONE
END
STYLE #arrow
GEOMTRANSFORM "end"
COLOR 0 255 0
SYMBOL "arrow-end"
SIZE 16.0
ANGLE AUTO
END # STYLE
END #CLASS
If I have either outer black or inner blue styles active the arrows show fine but when I turn both the outer and inner lines on the arrows get covered by the blue fill. Because the arrow is wider then the blue fill I can see that the outmost pixels of the arrow are rendered above the pixels of the outer black line making the arrow for example 40 pixels wide shows if very clearly. Thus if Gregor wants to see the endpoints it should be possible by using a symbol that is wider than the inner fill but the result is probably not beautiful.
-Jukka Rahkonen-
Gregor Karzelek wrote:
The STYLEs are rendered in the order they are encountered in the mapfile.
So if you want it on top then make it the last style block.
Have tried it. Has not worked with the GEOMTRANSFORMed STYLE. Can retry and send example on Tuesday when I'm back in the office.
Gregor Karzelek
Systemarchitekt
HELLER Ingenieurgesellschaft mbH
Otto-Hesse-Straße 19 / T3
64293 Darmstadt
Tel.: +49 6151 66846-16<tel:+49%206151%2066846-16>
Fax: +49 6151 66846-22<tel:+49%206151%2066846-22>
E-Mail: gregor.karzelek at heller-ig.com<mailto:gregor.karzelek at heller-ig.com>
Internet: www.heller-ig.com<http://www.heller-ig.com/>
Geschäftsführer: Dipl.-Ing. Henning Balck, Dipl.-Ing. Christian Komma
Handelsregister: Amtsgericht Darmstadt HRB 8310
Ust.-Ident.-Nr.: DE 217 293 137<tel:217%20293%20137>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140207/140c9fbf/attachment.html>
