[mapserver-users] "mapscript.imageObj(): is severely broken and should not be used" after upgrade from 6.0.1 to 6.2.1/6.4.0
Pavel Iacovlev
iacovlev.pavel at gmail.com
Wed Feb 12 03:15:13 PST 2014
http://mapserver.org/mapscript/php/phpmapscript.html#members
labelObj label Removed (6.2) - use addLabel, getLabel, ...
On Wed, Feb 12, 2014 at 11:34 AM, Tim Banchi <tim.banchi at gmail.com> wrote:
> Le 01/31/2014 11:23 AM, Tim Banchi a écrit :
> Hello,
>> with the upate from ubuntu 13.04 to 13.10 the package python-mapscript
>> moved from 6.0.1 to 6.2.1. Since then I get the the following runtime error:
>> img = mapscript.imageObj(fname)
>> File "/usr/lib/python2.7/dist-packages/mapscript.py", line 1324, in
>> __init__
>> this = _mapscript.new_imageObj(*args)
>> MapServerError: imageObj(): Image handling error. imageObj() is severely
>> The mapscript API suggests that mapscript.imageObj could be used
>> normally. So I added the ubuntugis-unstable repository and updated
>> python-mapscript to 6.4.0, but the error stays.
>> I didn't find anything usefull searching the internet for this error
>> message, so I wonder whether imageObj is really broken or whether the error
>> is caused by something else?
>> I'm not busy with mapscript, I have to maintain the program where
>> mapscript is part of. Can I use another function instead mapscript.imageObj
>> which gives me back an image object?
>> The function where mapscript.imageObj(fname) is invocated is as follows:
>> def load_custom_symbols(self):
>> lst_symbols = [ os.path.splitext(x) for x in
>> os.listdir(os.path.join(os.getcwd(),
>> "_symbols")) ]
>> for symbol, ext in lst_symbols:
>> if ext == ".png":
>> fname = os.path.join(os.getcwd(), "_symbols",
>> "".join([symbol, ext]))
>> symbol = mapscript.symbolObj(symbol)
>> symbol.type = mapscript.MS_SYMBOL_PIXMAP
>> symbol.setImage(img)
>> self.map.symbolset.appendSymbol(symbol)
>> Thanks!
>> Tim
> Hello,
> in case anybody else is wondering about these problem when moving from
> 6.0.1. to 6.2.1:
> After I learned that also labels where not working any more with 6.2. or
> 6.4:
> eg:
> class_layer = layer.getClass(i)
> class_layer.label.type = mapscript.MS_TRUETYPE
> caused:
> File "/usr/lib/python2.7/dist-packages/mapscript.py", line 841, in
> <lambda>
> __getattr__ = lambda self, name: _swig_getattr(self, classObj, name)
> File "/usr/lib/python2.7/dist-packages/mapscript.py", line 54, in
> _swig_getattr
> raise AttributeError(name)
> AttributeError: label
> I locked python-mapscript to the raring version (6.0.1) and since then
> everything is normal again: imageobj can be instantinated and labels are
> working as before
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140212/f07c7f9d/attachment-0001.html>
