[mapserver-users] Problem using WMS GetFeatureInfo in OpenLayers with different projections
Dejan Gambin
dejan.gambin at coin.hr
Fri Feb 14 01:24:35 PST 2014
I've upgraded to 6.4 and seems fine now
On 13. vel. 2014., at 16:09, Rahkonen Jukka (Tike) wrote:
> Hi,
> Just to eliminate one possibility, is the result the same if you use one DEM raster as a source instead of tileindex?
> -Jukka Rahkonen-
> Dejan Gambin wrote:
>> Since I didn't solve this yet, do you think it could be a bug and/or should I try
>> with some newer MapServer version? I am currently using 6.0.3
>> Thx
>> Dejan Gambin
>> On 22. sij. 2014., at 10:35, Dejan Gambin wrote:
>>> Sorry for being late...
>>> So, I have tested it all with browser of course. Here are some working and
>> non-working requests:
>>> Mapfile part:
>>> PROJECTION
>>> "init=epsg:4326"
>>> END
>>> METADATA
>>> "wms_srs" "EPSG:4326"
>>> "wms_title" "aster_dem"
>>> "gml_include_items" "value_0"
>>> "gml_value_0_alias" "Nadmorska_visina"
>>> END
>>> TILEINDEX "../aster/aster_index" #original raster in 4326
>>> Working GetMap request in 900913:
>>> http://mydomain.com/cgi-
>> bin/mywms/?SERVICE=WMS&VERSION=1.1.1&REQUEST=G
>> etMap&LAYERS=aster_dem_info&STYLES=&SRS=EPSG:900913&FORMAT=image
>> /png&W
>> IDTH=400&HEIGHT=300&BBOX=1496080.301904,5576310.226428,1593919.698
>> 096,
>>> 5649689.773572
>>> Non-working GetFeatureInfo request in 900913:
>> etFeatureInfo&LAYERS=aster_dem_info&STYLES=&SRS=EPSG:900913&FORMAT
>> =ima
>> ge/png&WIDTH=400&HEIGHT=300&BBOX=1496080.301904,5576310.226428,1
>> 593919
>> .698096,5649689.773572&QUERY_LAYERS=aster_dem_info&INFO_FORMAT=g
>> ml&X=2
>>> 00&Y=100
>>> Working GetMap request in 4326:
>> etMap&LAYERS=aster_dem_info&STYLES=&SRS=EPSG:4326&FORMAT=image/p
>> ng&WID
>>> TH=400&HEIGHT=300&BBOX=13.439518,44.712096,14.318424,45.178647
>>> Working GetFeatureInfo request in 4326:
>> etFeatureInfo&LAYERS=aster_dem_info&STYLES=&SRS=EPSG:4326&FORMAT=i
>> mage
>> /png&WIDTH=400&HEIGHT=300&BBOX=13.439518,44.712096,14.318424,45.17
>> 8647
>>> &QUERY_LAYERS=aster_dem_info&INFO_FORMAT=gml&X=200&Y=100
>>> On 17. sij. 2014., at 13:52, Rahkonen Jukka (Tike) wrote:
>>>> Hi,
>>>> Please show us the complete GetFeatureInfo requests for both cases. Server
>> urls are not interesting but all the WMS parameters. Have you already tried to
>> send them from browser? Testing with OpenLayers is waste of time because you
>> can't control what really happens but with hand written requests you are the
>> master.
>>>> -Jukka Rahkonen-
>>>> Lars Lingner wrote:
>>>>> On 17.01.2014 11:10, Dejan Gambin wrote:
>>>>>>> What is the mywms? MapServer binary, wrapper script, ...?
>>>>>> wrapper script. Something like:
>>>>>> #! /bin/sh MS_MAPFILE=/path_to_my_map_file export MS_MAPFILE
>>>>>> /usr/lib/cgi-bin/mapserv6
>>>>> AFAIK nothing wrong here.
>>>>>>> Did you check the actual requests? Does the bbox parameter fit to
>>>>>>> the srs? Could you compare a working GetFeatureInfo request in
>>>>>>> 900913 with a failing one in 4326?
>>>>>> Yes, bbox parameter fits to srs in both cases. So, if I put
>>>>>> bbox/srs params in 426 everything works, if I put them in 900913
>>>>>> then error happens
>>>>> Does other maps work with 900913?
>>>>> I would check which pro4 epsg file mapserver is using, check if
>>>>> there is a definition for 90013 and if it looks like
>>>>> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0
>>>>> ++y_0=0
>>>>> +k=1.0 +units=m +nadgrids=@null +wktext +no_defs
>>>>> On the other hand, if GetMap ist working fine, projection definition
>>>>> should be fine too. Just thinking out loud...
>>>>>>> Raise the debug level to 3 at map level and layer level. You can
>>>>>>> let MapServer write its own error logfile, so your apache log
>>>>>>> stays clean.
>>>>> Could you find anything in the MapServer log file?
>>>>> Here I would identify a working 4326 GFI request and compare the
>>>>> corresponding log with a 900913 request. There should be a difference.
>>>>> Best wishes,
>>>>> Lars
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
