[mapserver-users] Geotiff OUTPUTFORMAT fails in browse mode
Juanma M. R. juanma.mr at gmail.com
Thu Feb 20 01:04:07 PST 2014
Hi Steve,
First of all, thank you for your answer Steve.
I know it is old-style this way of requesting but I am trying to add
functionallity to a complex software based in this old-styled way of
working. I know that upgrading to the latest version of Mapserver would be
the best, however it implies resources and time that could be not
affordable right now as the existing and working map files would need
upgrade.
That is why I try working like that. I want to offer KMZ download and I was
trying to make a bridge to this format avoiding the upgrade of Mapserver by
updating GDAL, which can be done without having to update mapserver version
used by the system. Using the latest version of gdal_translate will make
affordable to get KMZ file from a GeoTIFF, for example, if I can store it
in the server side, which is what browse mode allows.
I know it sounds a bit complex, but updating the whole system is much more
complex and requires more efforts. Does anyone know why geotiff doesn´t
work in browse mode? Maybe is a limitation of these versions of mapserver,
4.10 and 5.6.6. If so, just knowing it would avoid me a lot of time
searching for it.
Cheers,
Juan Manuel Moreno Rivera.
Sección de Teledetección y SIG / Remote Sensing & GIS group
Instituto de Desarrollo Regional / Institute for Regional Development
Universidad de Castilla-La Mancha / University of Castilla-La Mancha
Tlf: +34 967599200 (Ext: 2623)
http://www.teledeteccionysig.es/
2014-02-19 17:25 GMT+01:00 Lime, Steve D (MNIT) <Steve.Lime at state.mn.us>:
>  Browse mode is for old-style interactive clients. That is, user click ->
> send to mapserver -> mapserver builds new page. You wouldn't use
> mode=browse to create georeferenced output like you're doing. Mode=map or
> WMS are the way to go.
> Steve
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Juanma M. R.
> *Sent:* Wednesday, February 19, 2014 9:24 AM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] Geotiff OUTPUTFORMAT fails in browse mode
> Dear all,
> I am trying to generate a georeferenced image with Mapserver. Now I am
> trying to do it with GeoTIFF.
> The issue is that all the outputformats are working in browse mode but
> GeoTiff. However, if I change to map mode, the URL request works and gives
> back the tiff data in stream to the browser.
> Is there any reason to GeoTIFF not working in browse mode, writting a file
> in the temporal folder from the server?
> My outputformat in .map file:
> OUTPUTFORMAT
>   NAME GEOTIFF_16
>   DRIVER "GDAL/GTiff"
>   MIMETYPE "image/tiff"
>   IMAGEMODE RGB
>   EXTENSION "tif"
> END
> I have checked the compilation of mapserver having the --with-tiff in both
> cases. And it is ok but the
> ./mapserv -v
> returns:
> MapServer version 4.10.7 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
> SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> SUPPORTS=WCS_SERVER SUPPORTS=GEOS SUPPORTS=POINT_Z_M INPUT=EPPL7
> INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> I don't know if this is relevant not having something like OUTPUT=TIFF but
> if no GeoTIFF support was included it shoudn't work neither in map mode,
> which works, should it?. The compilation was with no errors. This happens
> in both, Mapserver 4.10 and Mapserver 5.6.6.
> Regards,
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140220/bec7b297/attachment.html>
