[mapserver-users] Upgrading to 6.4.x
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Wed Feb 26 08:37:40 PST 2014
Ok, that was easy enough to fix.
For future reference, I did try using the WIDTH option, but I left the CIRCLE symbol in there and got an error.
So in the end, I deleted CIRCLE as a symbol, and changed SIZE to be WIDTH instead, now they look like the old ones, actually they might look even smoother now . . .
http://pwultra5.ci.stpaul.mn.us/tmp/samples/ms-6.4-MOD01.png
:c)
Thanks Tamas.
We're in the middle of moving everything over and trying to make a checklist of things to change in the Mapfiles to upgrade them.
-----Original Message-----
From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sent: Wednesday, February 26, 2014 10:06 AM
To: Basques, Bob (CI-StPaul)
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Upgrading to 6.4.x
How are you drawing those lines? Using a "circle" symbol as was required in pre-5 version is not supported anymore.
thomas
On 25 February 2014 22:08, Basques, Bob (CI-StPaul) <bob.basques at ci.stpaul.mn.us> wrote:
> All,
> Has anyone experienced a problem with MapServer not drawing short
> segments correct in the newer versions? I have a V5.4 that is
> outputting segmented lines (continuous but separate line segments)
> just fine. But the V6.4 version is not drawing small (visually) line
> segments, and leaving gaps in the line. The problem seems to be
> related to some sort of pixel threshold, if I zoom in, the lines become visually longer, and they display correctly.
> Am I explaining this correctly?
> Thanks
> Bobb
