[mapserver-users] Help with wcs output format
Andrea Peri
aperi2007 at gmail.com
Fri Jan 17 02:41:55 PST 2014
thx Thomas now it work !
My wrong was use the wrong name in wcs_formats.
Instead the wcs_formats need to have the value from NAME element of
outputformat or from the MIMETYPE element.
So the right setting is:
OUTPUTFORMAT
NAME GEOTIFF_16
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE FLOAT32
EXTENSION "tif"
END
OUTPUTFORMAT
NAME AAIGRID
DRIVER "GDAL/AAIGRID"
MIMETYPE "image/x-aaigrid"
IMAGEMODE INT16
EXTENSION "grd"
FORMATOPTION "FILENAME=result.grd"
END
and at layer level:
"wcs_formats" "GEOTIFF_16 AAIGRID"
or otherwise (same result):
"wcs_formats" "image/tiff image/x-aaigrid"
Many thx for your precious help.
Andrea.
2014/1/17 Thomas Bonfort <thomas.bonfort at gmail.com>
> Where does your FORMAT=GTiff come from? Try with FORMAT=image/tiff or
> FORMAT=GEOTIFF_16
> thomas
> On 17 janv. 2014, at 11:25, Andrea Peri <aperi2007 at gmail.com> wrote:
> > Hi,
> > I'm try to set a wcs server using mapserver.
> > using mapserver-trunk version.
> > I try to set an output of kind FLOAT 32 GDAL/Tiff
> > To do this I use this setting:
> > OUTPUTFORMAT
> > NAME GEOTIFF_16
> > DRIVER "GDAL/GTiff"
> > IMAGEMODE FLOAT32
> > EXTENSION "tif"
> > END
> > and at layer level I set this values:
> > "wcs_srs" "EPSG:3003"
> > "wcs_resolution" "75 75"
> > "wcs_bandcount" "1"
> > "wcs_formats" "GDAL/GTiff AAIGrid"
> > "wcs_nativeformat" " AAIGrid "
> > "wcs_rangeset_name" "Range 1"
> > "wcs_rangeset_label" "My Lable"
> > But when I retrieve the image,
> www502.regione.toscana.it/wmsraster/com.rt.wms.RTmap/wms?map=wcsdem&&SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCoverage&FORMAT=GTiff&COVERAGE=rt_dem.iddtm.10m.rt&BBOX=1552445.86499726003967226,4672361.01880083978176117,1787087.97314971010200679,4930453.35410698968917131&CRS=EPSG:3003&RESPONSE_CRS=EPSG:3003&WIDTH=490&HEIGHT=538
> > I retrieve an 8bit tif.
> > Perhaps is missing something in definition ?
> > Thx
> > Andrea Peri
> > qwerty àèìòù
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140117/907ca196/attachment.html>
