[mapserver-users] Mapserver WMS time support with Oracle
Rahkonen Jukka (Tike) jukka.rahkonen at mmmtike.fi
Tue Jan 21 06:25:20 PST 2014
Perhaps you can select the time into a format that Mapserver likes in your DATA by using to_char?
http://docs.oracle.com/cd/B19306_01/server.102/b14200/functions180.htm
-Jukka Rahkonen-
D. Nappo wrote
...but unfortunately MapServer wms time support doesn't include that format:
http://mapserver.org/it/ogc/wms_time.html
2014/1/21 D. Nappo <domenico.nappo at gmail.com<mailto:domenico.nappo at gmail.com>>
Many thanks!
It helped: the default date format in our system is DD-Mon-RR and I found it out with SELECT * FROM nls_database_parameters WHERE parameter LIKE '%DATE%'
2014/1/20 Umberto Nicoletti <umberto.nicoletti at gmail.com<mailto:umberto.nicoletti at gmail.com>>
On Mon, Jan 20, 2014 at 2:44 PM, D. Nappo <domenico.nappo at gmail.com<mailto:domenico.nappo at gmail.com>> wrote:
Hi there,
I couldn't figure out how to solve this. I have a layer so configured:
LAYER
      NAME "layer"
      TYPE point
      CONNECTION "conn_string...."
      CONNECTIONTYPE ORACLESPATIAL
      TEMPLATE     "templates/hotspot_template.html"
      DATA "SHAPE FROM (SELECT POINT as SHAPE, ACQ_DATE, ACQ_TIME, SATELLITE, CONFIDENCE, VERSION, BRIGHT_T31, FRP FROM gwsprd.HOT_SPOTS_MODIS) using unique OGR_FID"
      METADATA
            "wms_title"             "WMS test"
            "wms_srs"               "EPSG:4326"
            "wms_extent"            "-180 -90 180 90"
            "wms_timeextent" "2000-01-01/2020-12-31"
            "wms_timeitem" "acq_date"
            "wms_timedefault" "2014-01-01"
            "wms_timeformat" "YYYY-MM-DD"
Try with this:
"wms_timeformat" "DD-MM-YY"
it is the default format Oracle expects when converting a string to a date and no format has been explicitly provided.
Hth,
Umberto
            "wms_enable_request" "*"
        END
CLASS
            SYMBOL 'circle'
            SIZE 2
            COLOR        255 0 0
        END
    END
Now, the date column in the oracle table is the acq_date field.
The problem is that Mapserver translates that with a wrong oracle query (which it works in postgreslq, I guess):
SELECT OGR_FID,rownum, SHAPE FROM
(SELECT OGR_FID, POINT as SHAPE,  ACQ_DATE, ACQ_TIME, SATELLITE, CONFIDENCE, VERSION, BRIGHT_T31, FRP FROM gwsprd.HOT_SPOTS_MODIS)
WHERE  acq_date = '2014-01-16'
The query above uses a wrong filter and it gives the error:
ORA-01861: literal does not match format string
How can I tell to Mapserver to use a correct query??? Or do I missing anyhting???
Something like:
WHERE acq_date = to_date('2014-01-16','YYYY-MM-DD')
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140121/fb119294/attachment.html>
