[mapserver-users] raster gradient using python mapscript and postgis
Pasithee Jupiter
pasithee at gmail.com
Thu Jan 23 23:41:01 PST 2014
Hi All
I'm trying to use mapscript Python bindings to create a gradient on a
raster coming from PostGIS.
My Source looks like the following.
map_class = mapscript.classObj()
map_class.name = "test"
map_class.setExpression("([pixel] >= 0 AND [pixel] <= 1000)")
map_style = mapscript.styleObj()
map_style.rangeitem = "[pixel]"
map_style.maxcolor.setRGB(250, 250, 210)
map_style.mincolor.setRGB(178, 34, 34)
map_style.minvalue = 0
map_style.maxvalue = 1000
map_class.insertStyle(map_style)
layer.insertClass(map_class)
and the generated mapfile like this:
STATUS ON
TILEITEM "location"
TYPE RASTER
UNITS METERS
CLASS
NAME "test"
EXPRESSION ([pixel] >= 0 AND [pixel] <= 1000)
STYLE
RANGEITEM "[pixel]"
COLORRANGE 178 34 34 250 250 210
DATARANGE 0 1000
END # STYLE
END # CLASS
END # LAYER
The Problem is, that the gradient is never applied to the raster file. Here
(http://lists.osgeo.org/pipermail/mapserver-users/2011-November/070820.html)
the *RANGEITEM* is not set, but here (
http://mapserver.org/development/rfc/ms-rfc-6.html) they write that the
*RANGEITEM* is mandatory. So
- when I try to remove that *RANGEITEM* in the Python source, then the
STYLE section would be empty
- when I add it using the value *[pixel]* or *pixel,* the gradient is
Does anyone has an idea what I'm doing wrong?
Thanks a lot for any help
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140124/bb7cee7e/attachment.html>
