[mapserver-users] UTFGrid and Cluster, feature distinction: 0, single or clustered
Alexandre Dubé
adube at mapgears.com
Fri Jan 24 06:55:13 PST 2014
I just noticed that when using Clusters, only the non-clustered
features (singles) are returned in the grid, so clicking on a cluster is
like clicking on nothing. That explains the behavior I get.
I'll continue to look for a solution.
Alexandre
On 14-01-24 09:21 AM, Alexandre Dubé wrote:
> Hello MapServer community,
> I'm using the new UTFGrid [1] feature in MapServer in addition with
> Clusters [2] in an OpenLayers mapping application. I'm trying to
> implement the following feature: when the user clicks on a single
> point, a popup gets shown (this works already) and when he/she clicks
> on a clustered feature, then it must show different popup, without any
> info about the features inside, nor the extent of the features, but
> containing a simple link to invite the user to zoom in more.
> So basically, I'm looking for a way for the returned utfgrid data to
> know if the clicked element on the map is either: a single feature, a
> clustered feature or nothing at all. I thought I was close to a
> solution, but it didn't work as I expected. I thought of using the
> FeatureCount inside the UTFDATA and then use the value returned to
> determine the correct type:
> UTFDATA '{"c":[Cluster:FeatureCount]}'
> But the utf data only returns 2 values: 1 and 2. It returns 1 when
> it's a single feature, else 2 whenever it's a clustered feature
> (regardless of the actual real feature count) and it also returns 2
> when the user clicks on no feature at all. I'm not sure if my
> approach is a correct one, though...
> Does someone have any idea how I could accomplish what I'm trying to
> do ? I'm using a trunk version of MapServer I haven't updated for a
> couple months.
> Many thanks,
> Alexandre
> [1] http://mapserver.org/development/rfc/ms-rfc-93.html
> [2] http://mapserver.org/mapfile/cluster.html
> mapserver-users at lists.osgeo.org
