[mapserver-users] Help with expression
Thomas Bonfort
thomas.bonfort at gmail.com
Tue Jan 28 00:19:00 PST 2014
The expression seems fine as is. You seem to be using the xml mapfile
syntax, correct? Try posting the actual EXPRESSION written in the
mapfile, maybe the xml to mapfile conversion is failing here.
thomas
On 27/01/2014 22:20, Chrishelring wrote:
> Hi,
> I´m struggeling with an expression, hoping you guys can help. I need to
> select a subset of data using an expression like the one below.
> Status is char. Komnr, datoforsl, datovedt, datoaflyst are all integers
> I´m trying with the following expression but somehow it´s not working..
> expression>('[status]' = 'K' AND [komnr] = 175 AND [datoforsl] = 0 AND
> [datovedt] = 0 AND [datoaflyst] = 0)</expression>
> Any ideas?
> Christian
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Help-with-expression-tp5100327.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
