[mapserver-users] Layer with over 6000 shapefiles
Thomas Bonfort
thomas.bonfort at gmail.com
Wed Jan 29 08:40:29 PST 2014
you should use ogrtindex for vector files, not gdaltindex
thomas
On 29/01/2014 17:32, EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE wrote:
> Hi,
> Is there a way to add a layer that points to 6000 some odd shapefiles? I've created a set of contour files for the whole world, and when I had the info in a single shapefile it was about 260GBs. Mapserver would serve it up, but performance was horrible. I now have the set broken up into about 6000 separate shapefiles, but don't know how to address that in a single layer. I tried using gdaltindex, to create a single index file that points to all the other shapefiles, but I get an error saying the shapefiles are an unsupported type. Is there some other way to create an index that Mapserver can use to point to this many shapefiles?
> Thanks,
> James
> mapserver-users at lists.osgeo.org
