[mapserver-users] Layer with over 6000 shapefiles
EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
james.evans.4 at us.af.mil
Wed Jan 29 10:16:40 PST 2014
I was off on the size of the shape file. It's 265MB, not GB. Doh! Anyway, the performance when processing that files was still surprisingly bad. Quad core server and all 4 core's were maxed out for about 5 minutes after just loading that layer on a client. I am running Server 2003, and only have 4GB ram on that server. We are looking at replacing it.
James
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Even Rouault
Sent: Wednesday, January 29, 2014 11:09 AM
To: mapserver-users at lists.osgeo.org; Brent Wood
Subject: Re: [mapserver-users] Layer with over 6000 shapefiles
Le mercredi 29 janvier 2014 18:40:49, Brent Wood a écrit :
> This is less a mapserver issue than a data management issue - and
> shapefiles are not a particularly good way to manage data.
> I suggest you look at a spatially enabled database, with attribute &
> spatial indexes, such as Postgis, instead of shapefiles as a data source.
> These are pretty much designed for such use cases.
> That said, if you cannot use a spatial database in this case, you can
> do things with mapserver to improve things - like have multiple layers
> (though 6000 seems a bit excessive) in a single group - so addressable
> as a single layer but each with its own shapefile spatial index file.
A spatialite DB with spatial index could also perhaps do it. Not sure if it scales well up to 260 GB however.
> Brent Wood
> ________________________________
> From: "EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE"
> <james.evans.4 at us.af.mil> To: "mapserver-users at lists.osgeo.org"
> <mapserver-users at lists.osgeo.org> Sent: Thursday, January 30, 2014
> 5:32 AM
> Subject: [mapserver-users] Layer with over 6000 shapefiles
> Hi,
> Is there a way to add a layer that points to 6000 some odd shapefiles?
> I've created a set of contour files for the whole world, and when I
> had the info in a single shapefile it was about 260GBs. Mapserver
> would serve it up, but performance was horrible. I now have the set
> broken up into about 6000 separate shapefiles, but don't know how to
> address that in a single layer. I tried using gdaltindex, to create a
> single index file that points to all the other shapefiles, but I get
> an error saying the shapefiles are an unsupported type. Is there some
> other way to create an index that Mapserver can use to point to this
> many shapefiles? Thanks, James
Geospatial professional services
http://even.rouault.free.fr/services.html
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140129/3e93127f/attachment-0001.bin>
