[mapserver-users] Layer with over 6000 shapefiles
EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE
james.evans.4 at us.af.mil
Wed Jan 29 10:27:43 PST 2014
The Tile4ms utility is kicking out an error on some of the larger shape
files, saying the .dbf doesn't match the file. Whatever that means. I can
still load the "bad" shapefiles in Global Mapper, and they appear to be
correct. I'm reprocessing the data now to cut down on the number of files.
I should end up with a 48x16 grid covering the whole world. Hopefully I can
get that working with an index and speed things up when displaying this
layer.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Wednesday, January 29, 2014 9:46 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Layer with over 6000 shapefiles
On 1/29/2014 11:37 AM, Jeff McKenna wrote:
> On 1/29/2014, 12:32 PM, EVANS, JAMES R GS-13 USAF ACC 84 RADES/SCZE wrote:
>> Hi,
>> Is there a way to add a layer that points to 6000 some odd shapefiles?
I've created a set of contour files for the whole world, and when I had the
info in a single shapefile it was about 260GBs. Mapserver would serve it
up, but performance was horrible. I now have the set broken up into about
6000 separate shapefiles, but don't know how to address that in a single
layer. I tried using gdaltindex, to create a single index file that points
to all the other shapefiles, but I get an error saying the shapefiles are an
unsupported type. Is there some other way to create an index that Mapserver
can use to point to this many shapefiles?
>> Thanks,
>> James
> You can use the MapServer "tile4ms" utility
> (http://mapserver.org/utilities/tile4ms.html). There are some good
> examples on that page for you to follow.
Check the results from tile4ms with shpdump and make sure that you dont have
all null shapes. I have run into this on Ubuntu. I believe in both the
packages and compiling for source. I haven't had time to run down what the
issues are.
-Steve
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140129/f015dd0b/attachment.bin>
