[mapserver-users] WFS GetFeature sometimes returns 'missing' even when there are matching features
Lime, Steve D (MNIT) Steve.Lime at state.mn.us
Tue Jul 22 08:30:03 PDT 2014
Hmmm... map->query.rect is used to set the searchrect. I wonder how that is populated initially. I would have thought it would have taken the map->extent in the first place if an extent was not explicitly set. It seems like this should be fixed upstream someplace. Your fix is reasonable but should be applied before the tolerance unit block.
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Gertjan van Oosten
Sent: Thursday, July 17, 2014 7:07 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] WFS GetFeature sometimes returns 'missing' even when there are matching features
A WFS GetFeature request like this one:
  <wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs" service="WFS" version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
    <wfs:Query typeName="feature:Results_wfs">
      <wfs:PropertyName>FEATURE_ID</wfs:PropertyName>
    </wfs:Query>
  </wfs:GetFeature>
sometimes returns 'missing' like so:
  <?xml version='1.0' encoding="ISO-8859-1" ?>
  <wfs:FeatureCollection
     xmlns:ms="http://mapserver.gis.umn.edu/mapserver"
     xmlns:gml="http://www.opengis.net/gml"
     xmlns:ogc="http://www.opengis.net/ogc"
     xsi:schemaLocation="http://mapserver.gis.umn.edu/mapserver http://localhost/mapserv?SERVICE=WFS&VERSION=1.1.0&REQUEST=DescribeFeatureType&TYPENAME=feature:Results_wfs&OUTPUTFORMAT=text/xml;%20subtype=gml/3.1.1  http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
     <gml:boundedBy>
	<gml:Null>missing</gml:Null>
     </gml:boundedBy>
  </wfs:FeatureCollection>
even when there is a matching feature. This happens with Mapserver 6.4.1 and Oracle 11.2. I've traced it down to the searchrect in msQueryByRect() inside mapquery.c being "empty":
  {minx=-1, maxx=-1, miny=-1, maxy=-1}
This is caused by the way the extent is computed:
   msOracleSpatialLayerGetExtent. Using this Sql to retrieve the extent:
   SELECT SDO_GEOM.SDO_CONVEXHULL(link_geo, 0.001000) AS GEOM from (...)
The convex hull is NULL for some features. As the documentation says:
  http://docs.oracle.com/cd/E11882_01/appdev.112/e11830/sdo_objgeom.htm#SPATL1114
  "The function returns a null value if geom1 is of point type, has
  fewer than three points or vertices, or consists of multiple points
  all in a straight line."
I indeed have features like that, so in this case no features are returned at all. That is obviously not right. If I add these three lines it works correctly and my features are returned:
--- mapserver-6.4.1/mapquery.c.distrib	2014-01-02 13:41:49.000000000 +0100
+++ mapserver-6.4.1/mapquery.c	2014-07-17 13:58:36.000000000 +0200
@@ -1055,30 +1055,33 @@
     searchrect = map->query.rect;
     if(lp->tolerance > 0) {
       layer_tolerance = lp->tolerance;
       if(lp->toleranceunits == MS_PIXELS)
         tolerance = layer_tolerance * msAdjustExtent(&(map->extent), map->width, map->height);
       else
         tolerance = layer_tolerance * (msInchesPerUnit(lp->toleranceunits,0)/msInchesPerUnit(map->units,0));
       searchrect.minx -= tolerance;
       searchrect.maxx += tolerance;
       searchrect.miny -= tolerance;
       searchrect.maxy += tolerance;
+    if (searchrect.minx == -1 && searchrect.maxx == -1 && searchrect.miny == -1 && searchrect.maxy == -1) {
+      searchrect = map->extent;
     msRectToPolygon(searchrect, &searchshape);
     /* Raster layers are handled specially. */
     if( lp->type == MS_LAYER_RASTER ) {
       if( msRasterQueryByRect( map, lp, searchrect ) == MS_FAILURE)
         return MS_FAILURE;
       continue;
     /* Paging could have been disabled before */
     paging = msLayerGetPaging(lp);
     msLayerClose(lp); /* reset */
     status = msLayerOpen(lp);
I.e if the query rectangle can't be computed for some reason, fall back to the map extent. I don't know if this is the best fix, but it is the simplest that I could find. Is this the right way to do it?
Kind regards,
-- Gertjan van Oosten, Principal Consultant, West Consulting B.V.
-- gertjan at West.NL     +31 15 2191 600       www.west.nl
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
