[mapserver-users] Σχετ: Mapserver can't read mapfile
Stefanos Anastasiou
emperor_stef at yahoo.gr
Sun Jun 1 12:31:45 PDT 2014
Hi Jeff,
I came to this old post once again and I tried the above mentioned. shp2img still produces an image which is blank or whatever the color of the mapfile is defined. On the other hand I checked the EXTENT once again and it was wrong so I changed to the appropriate one (EXTENT 17.00 33.00 32.00 42.00) which I checked on QGIS in WGS84 so it should be fine. If STATUS is set to default or On there's no difference. I also changed TYPE to line and polygon just to be sure but nothing.
My shapefile is a polygon with boundaries. Why wouldn't it appear on the browser?
Thanks again and I'm sorry for writing about it so late.
Stefanos
Στις 7:15 μ.μ. Δευτέρα, 10 Φεβρουαρίου 2014, ο/η Jeff McKenna <jmckenna at gatewaygeomatics.com> έγραψε:
Hi sorry long thread and I bet this has already been said, but here were
my thoughts when I read your problems:
- always test your mapfile at the commandline first, using the shp2img
utility (http://mapserver.org/utilities/shp2img.html). Once your layers
look find there in the generated map image then move to your application
- if using MapServer CGI (mode=map), a blank map often means you are not
specifically telling MapServer to turn on layers; try adding &LAYERS=all
- or setting each of your layer's STATUS values to DEFAULT might work
(but this can cause lots of trouble later, so this is not often recommended)
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2/10/2014, 11:15 AM, Stefanos Anastasiou wrote:
> Hello!!
> I'am having my mapfile place in /home/mapdata folder whereas I also keep
> a couple of other mapfiles too.
> I'm trying to load it in the following form on the
> browser: http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop.map&mode=map
> and all I get is a blank page. No errors no nothing.
> Then I created an html template in order to click it from there by
> creating a simple link (and not a from) in the following hyperlink: <a
> href="http://127.0.0.1/cgi-bin/mapserv?map=/home/mapdata/pelop/map&mode=map>
> This link </a>
> And I get the following error: msLoadMap(): Unable to access file.
> Last time this happened I was invoking Mapserver through a form but this
> time it's just a simple link.
> Why is it happening ?
> The weird thing is that all the other mapfiles that are seem to be
> working are are having the same permission settings with the
> current: -rw-r--r--
> Thanks a lot!
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140601/003adcbf/attachment.html>
