[mapserver-users] Ubuntu 14.04 and Mapserver 6.4.1-2
Haug, Jim
Jim.Haug at state.sd.us
Mon Jun 2 13:14:36 PDT 2014
I recently upgraded to Ubuntu 14.04 with no visible issues.
The url below is generated in my web page code and is sent to the mapserver:
http://hawken.sdsmt.edu/cgi-bin/mapserv?mode=itemnquery&qformat=png&map=/gisdata/sd/sd_x-printform.map&qlayer=surveys&qitem=archive&qstring=/ESD-0498/i&layer=sites&layer=drg024k_13N&layer=drg024k_14N&layer=drg250k_13N&layer=drg250k_14N&layer=sd_plss&layer=sd_tr&mapsize=480+480&mapext=shape&scaledenom=932875
It worked fine in Ubuntu 13.10 using Mapserver version 6.2.1-3 and generated a map properly. It no longer works in mapserver 6.4.1-2 in Ubuntu 14.04. Now I get the error message
mapserv(): Web application error. Parameter 'qstring' value fails to validate. msValidateParameter(): Regular expression error. Parameter pattern validation failed.
None of my underlying data or map files have changed. I'm completely mystified as to why this is happening. I hope I don't have to revert to Ubuntu 13.10, but I have a backup in case I need to.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140602/4918b703/attachment.html>
