[mapserver-users] How to use ANNOTATION layer in combination with RASTER data?
Jorrit Goddijn
Jorrit.Goddijn at meteogroup.com
Wed Jun 4 03:08:40 PDT 2014
Hi Jörg, Hi Stephen,
Instead of showing the grayscaled pixels of the RASTER image, I would like to show the actual value.
I have my data only in GRIB format available, so creating a point layers and using the FEATURE attribute is not possible as I would need the data as a shapefile for that, I am right?
Is there anyway to accomplish this?
Thanks for your time,
Jorrit
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jörg Thomsen
Sent: dinsdag 3 juni 2014 14:17
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] How to use ANNOTATION layer in combination with RASTER data?
Hi Jorrit,
you want to label you raster dataset with what?
Regards, Jörg
Am 03.06.2014 14:01, schrieb Jorrit Goddijn:
> Hi all,
> I try draw an ANNOTATION type layer based on RASTER type layer. When
> doing this based on a shape file I would set the LABEL item on the
> ANNOTATION layer to be attribute used in the shapefile.
> What LABELITEM should I use when using RASTER data?
> I posted the Mapfile I have so far hereunder.
> Thank you for your help.
> Bye
> Jorrit
> #grib wave direction layer example
> LAYER
> NAME "grib_data"
> TYPE RASTER
> DATA
> "/var/www/mapserver/data/grib/routeguard/4nwcurpol99_2013110412.grb2"
> #Current direction @ Mean sea level
> PROCESSING "BANDS=1"
> PROCESSING "SCALE=0,360" #scale all degrees
> PROJECTION
> "+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs +pm=-360"
> END
> END
> # the annotation layer
> LAYER
> NAME "grib_label"
> DATA "grib_data"
> STATUS OFF
> TYPE ANNOTATION
> CLASSITEM "CLASS" # do I need it?
> LABELITEM "VAR_10-1-0_L101" #what variable name to use?
> CLASS
> EXPRESSION [VAR_10-1-0_L101] #gives parse error
> STYLE
> COLOR -1 -1 -1
> END
> LABEL
> COLOR 132 31 31
> TYPE TRUETYPE
> FONT arial-bold
> SIZE 12
> ANTIALIAS TRUE
> POSITION CL
> PARTIALS FALSE
> MINDISTANCE 300
> BUFFER 4
> END # end of label
> END # end of class
> END # annotation layer
