[mapserver-users] Mapserver installation trouble in ubuntu server
Hugo
hfpmartins at gmail.com
Wed Jun 4 05:18:30 PDT 2014
I have done those configurations but i guess i should have some problems
with virtual hosts that were setup in the machine. Now i'm sure that this
is the configuration that is not being read and can focus on that.
Thanks a lot for your help.
Cheers,
On 4 Jun 2014 12:43, "Rahkonen Jukka (Tike)" <jukka.rahkonen at mmmtike.fi>
wrote:
> Hi,
> I guess that you must tell Apache that mapserv should be run as cgi-bin
> script. I found the following snippet from httpd.cong file but that file is
> not in use and I do not know if it is valid.
> <Directory "${HOME}/www/cgi-bin">
> SetHandler cgi-script
> <Files "mapserv">
> SetHandler fcgid-script
> -Jukka Rahkonen-
> Hugo wrote:
> Hi all,
> I'm having some troubles with a mapserver installation in a hosted ubuntu
> server (12.04).
> I've installed it using the regular procedures (apt-get install
> mapserver-bin cgi-mapserver) and i can see from the console that it is
> installed correctly. However, when i try to access it from the browser,
> using the url http:/ip_address/cgi-bin/mapserv it starts to download the
> bin file and does not display the typical message (No query information to
> decode...).
> I remember that i have had this issue some time ago and don't remember how
> i fixed it... i know it is something really simple that i'm missing here.
> Could you guys give me some help?
> Kind regards,
> Hugo Martins
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140604/84db86c0/attachment.html>
