[mapserver-users] Question about config Mapserver to provide SOS service from postgis table/view
Miguel-Angel Manso-Callejo (UPM)
m.manso at upm.es
Mon Jun 16 07:19:05 PDT 2014
Dear Till
I'm trying to publish real time steam data computed on a permanent
network of GPS stations and stored on a PostGIS DataBase.
This network have 300 stations and i want to publish individual
observation as a procedure result.
As i have informed this morning to the list, i have gotten to start the
service and made that the response to GetObservarion request offer the
O&M result.
To enable the service use in the same postgis data table to handle
several columns (observed variables) i have used sos_procedure_item as
set assefa (http://trac.osgeo.org/mapserver/ticket/2050)
Then to solve problem to access postgis data filtering to one of the gps
station, i have put:
DATA "pos from (select pos,fecha,vap from vaporcolumna where
id='MADR13407S012') as subquery using unique fecha using srid=4326"
In order to enable time filtering to procedure values, i have put:
"sos_timeitem" "fecha"
Then mu questions now are:
1º.- when i tryed to do request getObservation using parameter
/&procedure=urn:ogc:def:procedure/:XXX SOS don't recognize any procedure.
How can i do to enable a procedure name in mafile configuration?
2º.- when i tryed to do a request getObservation using
&eventtime=2014-01-01T00:00:00+01/2014-01-31T00:00:00+01 SOS don't
recognize this timestamp format
How must be set the time period to eventTime paramenter?
Regards,
Miguel A
El 16/06/2014 14:09, Till Adams escribió:
> Dear Miguel,
> it is not clear, where exactly your problem is as you do not tell the
> list, what is going wrong.
> Did you check the sos-howto documentation-site:
> http://mapserver.org/ogc/sos_server.html ?
> There are some more definitnions in the mapfile header required.
> Another problem - are you sure, that your DATA-request really delivers
> some data? For the first step it's always clever to ensure, that the
> surrounding really works, so you can focus on the main problem, which
> is configuring the sos-layer.
> Regards, Till
> Am 15.06.2014 20:16, schrieb Miguel-Angel Manso-Callejo (UPM):
>> Dear all,
>> I'm trying to config mapserver to offer through SOS data stored in two
>> tables joined by a view.
>> I'm trying to offer in the first step only one time serial data and i'm
>> using this configuration:
>> LAYER
>> NAME "test_sos_layer"
>> METADATA
>> "sos_procedure" "vaporcolumna" ## REQUIRED
>> "sos_procedure_item" "vap"
>> "sos_offering_id" "MADR13407S012" ## REQUIRED
>> "sos_observedproperty_id" "vap"
>> "sos_observedproperty_name" "Vapor_agua_columna"
>> "sos_offering_timeextent" "2010/2014"
>> "sos_describesensor_url"
>> "http://138.100.61.23:90/sensorml/MADR13407S012.xml" ## REQUIRED
>> "sos_offering_name" "GPS Station in Madrid 13407S012"
>> END
>> TYPE POINT
>> STATUS ON
>> CONNECTIONTYPE POSTGIS
>> CONNECTION "host=127.0.0.1 port=5432 dbname=example_postgis21
>> user=postgres password=postgres"
>> DATA "pos, vap from vaporcolumna where id='MADR13407S012' "
>> PROJECTION
>> "init=epsg:4326"
>> END
>> CLASS
>> NAME "vap"
>> STYLE
>> COLOR 255 0 0
>> SYMBOL "circle"
>> SIZE 8
>> END
>> END
>> END
>> View have this fields:
>> Id (pk), pos (geometry), vap (double), fecha (date)
>> Can any one help me informing what i'm doing bad or how must i config in
>> order to do it?
>> Regards,
>> Miguel A.
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140616/27398816/attachment.html>
