[mapserver-users] Masking POINT layers with CONNECTIONTYPE UVRASTER
Jorrit Goddijn
Jorrit.Goddijn at meteogroup.com
Fri Jun 20 02:05:48 PDT 2014
Hi all,
We're still having issues with the MASK attribute in combination with layers with CONNECTIONTYPE set to UVRASTER, so I thought of bringing this under the attention again.
The layer draws fine without the MASK. But when I use the MASK attribute, I get a NO DATA RECEIVED error, and no image is drawn.
Does anybody have a workaround for this?
Thank you,
Jorrit
LAYER
NAME "current_grid"
TYPE POINT
CONNECTIONTYPE uvraster
STATUS OFF
MASK "water_outline" #yields NO DATA RECEIVED error
DATA "path/to/grib2/file"
PROCESSING "BANDS=1,2"
CLASS
STYLE
SYMBOL "arrow"
ANGLE [uv_angle]
SIZE 10
COLOR 0 255 0
END # style
END # class
PROJECTION
"+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs +pm=-360"
END
METADATA
"wms_title" "the current arrow grid"
"wms_srs" "epsg:4326 epsg:54004"
END
END # layer
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140620/a81a2046/attachment.html>
