[mapserver-users] PostGIS Connection Failure
Krishna Priya Patury
krishna.patury at gmail.com
Tue Jun 24 06:30:44 PDT 2014
Hi All,
Any other ideas?
The map server application installed outside of my Centos VM can connect to
the Postgres database on the VM. I can also connect to the database both
from within and outside the VM using psql.
I believe the Mapserver installation on my VM is fine too as my shp2img and
running the mapserver through command line work just fine. The issue is
only when I try to connect to the database through the application from my
VM.
I do not see anything additional in the logs. I can see that the database
logs are not updated when I hit it though the application within the VM,
understandably so with the error message in the browser.
The only difference between running shp2img and the application is perhaps
the user? I was able to open a succesful connection through psql as an
'apache' user as well(User which is running the Apache server). So am not
sure what is missing.
Thanks,
Krishna.
On Mon, Jun 23, 2014 at 5:24 PM, Krishna <krishna.patury at gmail.com> wrote:
> Yes I can connect to Postgres using the same connection information
> through psql both from within and outside my vm.
> Sent from my iPhone
> > On Jun 23, 2014, at 5:20 PM, Paul Ramsey <pramsey at cleverelephant.ca>
> wrote:
> > Did you restart your postgresql after making the changes to pg_hba and
> postgresql.conf? Can you telnet to port 5432? Can you connect with psql?
> Just ignore mapserver for now, you have a connection issue.
> > P.
> > http://postgis.net
> > http://cleverelephant.ca
> > On June 23, 2014 at 2:17:19 PM, Krishna (krishna.patury at gmail.com)
> wrote:
> >>> As I mentioned I have disabled the firewall. Or so I think. When
> >> I login as 'root' and click firewall it says disabled. Any way
> >> I can confirm/ test this?
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140624/7f9da698/attachment.html>
