[mapserver-users] Σχετ: htdocs settings and mapfile status
Stefanos Anastasiou
emperor_stef at yahoo.gr
Wed Jun 25 12:03:59 PDT 2014
Hi Bobb,
thanks for the answers. Regarding the html templates: I thought that html files are kept in htdocs since this is the DocumentRoot from where apache is configured to read files from. So if I don't need to keep files in htdcos where else can I put them and how can apache understand where they are put.
Regarding the On / default status: is this chunk put in the template or the mapfile?
Stefanos
Στις 5:38 μ.μ. Τρίτη, 24 Ιουνίου 2014, ο/η Stefanos Anastasiou <emperor_stef at yahoo.gr> έγραψε:
Hi list. I have two questions that are confusing me a little bit.
First of all I am keeping all my HTML template files /usr/local/apache2/htdocs. This folder has read-only permission settings by default so every time I want to edit/create a template I use nano or pico through terminal with root privileges. So, would it be wise (would it be secure?) to make htdocs folder have read/write permission and if not what other way is there so I can edit/make template files easily?
Another question is that when I make my mapfile and set STATUS to default everything works fine. But when it's set to on I get a blank page (needless to mention about STATUS off). That's not normal right?
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140625/f5af2ed6/attachment.html>
