[mapserver-users] Shapezip 3D
Even Rouault
even.rouault at mines-paris.org
Mon Mar 3 01:16:19 PST 2014
Selon Guillaume Sueur <no-reply at neogeo-online.net>:
> Hi Even,
> Thanks for your reply even if it is disappointing. So I guess all the
> http://mapserver.org/fr/output/ogr_output.html stuff about 2.5D/3D is
> just rubbish and the USE_POINT_Z_M compile option is useless.
Actually.... no, it is correct. My previous comment was on the input interface
of MapServer with OGR, where Z support is not currently available. But for the
output part (mapogroutput.c), Z support should work. So you could likely use a
3D shapefile (with MapServer native shapefile connection) and output a 3D
shapezip.
> Thanks for your investigations
> Best regards
> Guillaume
> Le 01/03/2014 12:53, Even Rouault a écrit :
> > Le vendredi 28 février 2014 17:29:15, Guillaume Sueur a écrit :
> >> Hi list,
> >> I'm trying to generate a 3D shapefile with OGR SHAPEZIP format. I'm
> >> using MapServer 6.5 compiled with USE_POINT_Z_M options.
> >> mapserv -v gives :
> >> MapServer version 6.5-dev OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
> >> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV
> >> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> >> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> >> SUPPORTS=GEOS SUPPORTS=POINT_Z_M INPUT=JPEG INPUT=POSTGIS INPUT=OGR
> >> INPUT=GDAL INPUT=SHAPEFILE
> >> My data are stored in Postgis 2.1. They are 3D. I've added the
> >> "ows_geomtype" "MultiPolygon25D" metadata to my layer.
> >> What I get is a 3D shapefile, but all the Z values are set to 0.
> >> Lookking at the request made by MapServer to Postgis, I see the geom is
> >> requested with Force2D function :
> >> encode(ST_AsBinary(ST_Force2D("the_geom"),'NDR'),'hex') as geom
> >> Is this a bug or is there some more settings I didn't set properly ?
> > Guillaume,
> > there's no support yet for parsing 3D geometries in mappostgis.c
> (mentionned
> > in comments of https://github.com/mapserver/mapserver/pull/4803 ). I
> wouldn't
> > expect adding support for it to be that difficult.
> > As a workaround, I would have suggested that you could use the OGR
> PostgreSQL
> > driver, but looking at mapogr.cpp, I also see that the Z support of OGR
> isn't
> > used. Grrrr....
> > Even
