[mapserver-users] Can't get a raster to display... projection issue?
Peter Gustafson pgustafson at gmail.com
Thu May 1 08:43:55 PDT 2014
Hi all, this didn't help and it is still not working. (1 month later).  Any
further suggestions?  Does anyone know of a simple, fully functional raster
only example?  Thanks,
On Tue, Apr 1, 2014 at 6:08 PM, thomas bonfort <thomas.bonfort at gmail.com>wrote:
> typo: epsg:3857 instead of 3587?
> thomas
> On 1 April 2014 23:53, Peter Gustafson <pgustafson at gmail.com> wrote:
> > Hi all, I'm brand new to mapserver.
> > (The itasca workshop map works)
> > I can't get a raster to display. I've tried various extents and
> projections
> > but suspect these are the cause. The mapfile is as below (IMAGEPATH and
> > IMAGEURL are changed -- working with itasca) as well as info from gdal.
> > Your help would be greatly appreciated!
> > Thanks,
> > Pete
> > MAP
> >         NAME MyMap
> >         STATUS ON
> >         CONFIG "MS_ERRORFILE" "ms_error.txt"
> >         DEBUG 5
> >         STATUS ON
> >         SIZE 1000 600
> >         EXTENT -20037508.34 -20037508.34 20037508.34 20037508.34
> >         UNITS METERS
> >         SHAPEPATH "data"
> >         IMAGECOLOR 255 255 255
> >         PROJECTION
> >                 "init=epsg:3587"
> >         END
> >         WEB
> >             IMAGEPATH "/var/www/localhost/htdocs/tmp/"
> >             IMAGEURL "tmp/"
> >         END
> >         LAYER
> >                 NAME "wac-48_1_4.tif"
> >                 DATA "wac-48_1_4.tif"
> >                 TYPE RASTER
> >                 TRANSFORM TRUE
> >                 STATUS ON
> >                 UNITS DD
> >                 PROJECTION
> >                         "init=epsg:4326"
> >                 END
> >         END
> > END
> > Driver: GTiff/GeoTIFF
> > Files: data/wac-48_1_4.tif
> > Size is 512, 512
> > Coordinate System is:
> > GEOGCS["WGS 84",
> >     DATUM["WGS_1984",
> >         SPHEROID["WGS 84",6378137,298.257223563,
> >             AUTHORITY["EPSG","7030"]],
> >         AUTHORITY["EPSG","6326"]],
> >     PRIMEM["Greenwich",0],
> >     UNIT["degree",0.0174532925199433],
> >     AUTHORITY["EPSG","4326"]]
> > Origin = (-95.777952659785427,49.001030999999998)
> > Pixel Size = (0.019025026914202,-0.019025026914202)
> > Metadata:
> >   AREA_OR_POINT=Area
> > Image Structure Metadata:
> >   COMPRESSION=LZW
> >   INTERLEAVE=PIXEL
> > Corner Coordinates:
> > Upper Left  ( -95.7779527,  49.0010310) ( 95d46'40.63"W, 49d 0' 3.71"N)
> > Lower Left  ( -95.7779527,  39.2602172) ( 95d46'40.63"W, 39d15'36.78"N)
> > Upper Right ( -86.0371389,  49.0010310) ( 86d 2'13.70"W, 49d 0' 3.71"N)
> > Lower Right ( -86.0371389,  39.2602172) ( 86d 2'13.70"W, 39d15'36.78"N)
> > Center      ( -90.9075458,  44.1306241) ( 90d54'27.16"W, 44d 7'50.25"N)
> > Band 1 Block=512x5 Type=Byte, ColorInterp=Red
> > Band 2 Block=512x5 Type=Byte, ColorInterp=Green
> > Band 3 Block=512x5 Type=Byte, ColorInterp=Blue
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140501/9f5d4ca8/attachment.html>
