[mapserver-users] MapServer calculates wrong WGS84BoundingBox for WCS request using EPSG:28992
Christian Braun
christian.braun at tudor.lu
Wed May 14 01:30:47 PDT 2014
Dear list members,
I just discovered that my MapServer installation is calculating a wrong WGS84BoundingBox tag.
I know that were issues in the past with the definition of EPSG:28992 in which my data is stored. I was checking all epsg files on the system and als set the config flag for PROJ_LIB in the map file. But it seems that MapServer is still ignoring the correct settings for EPSG:28992 and takes the "old" definition without proper proj towgs flags.
The services are public and you can find below the links [1] to a DescribeCoverage for the WCS I am refering to. ro_dsm_mini is a small layer which I am using for testing. BBOX in 28992 is the correct one of the data source, the corresponding WGS84BoundingBox which is giving back is wrong.
I am using http://cs2cs.mygeodata.eu for checking.
I also paste the relevant part of the map file [2].
Any further help is appreciated.
Many thanks in advance,
Christian
[1]
http://maps.iguess.tudor.lu/cgi-bin/mapserv?map=/srv/mapserv/MapFiles/RO_localOWS_test.map&SERVICE=WCS&VERSION=1.1.0&REQUEST=DescribeCoverage&COVERAGEID=ro_dsm_mini
[2]
MAP
NAME "TUDOR_RO_test-environment"
EXTENT 65956 431299 93267 451459
SIZE 800 600
MAXSIZE 50000
UNITS METERS
SHAPEPATH "/srv/sampleData/"
IMAGECOLOR 255 255 255
PROJECTION
#"+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +towgs84=565.237,50.0087,465.658,-0.406857,0.350733,-1.87035,4.0812 +units=m +no_defs"
"init=epsg:28992"
END
CONFIG PROJ_LIB "/usr/share/proj/"
LAYER # -----------------------------------------------------------------
NAME "ro_dsm_mini"
TYPE RASTER
STATUS ON
DATA "ro_dsm_mini.tiff"
#PROCESSING "SCALE=AUTO"
PROJECTION
"+proj=sterea +lat_0=52.15616055555555 +lon_0=5.38763888888889 +k=0.9999079 +x_0=155000 +y_0=463000 +ellps=bessel +towgs84=565.237,50.0087,465.658,-0.406857,0.350733,-1.87035,4.0812 +units=m +no_defs" # the projection of the source data set
#"init=epsg:28992"
END
METADATA
"ows_title" "DSM subset"
"ows_abstract" "This a test data set of Rotterdams DSM subset"
"wms_include_items" "value_0"
"wms_value_0_alias" "Height"
"wcs_label" "ro_dsm_mini" ### required
"wcs_rangeset_name" "Range 1" ### required to support DescribeCoverage request
"wcs_rangeset_label" "My Label" ### required to support DescribeCoverage request
"wcs_formats" "img"
END
Christian Braun
R+D Engineer
Environmental Modelling, Geocomputation
Tel: +352- 425991-6608
Mobil: +49-179-6845896
Mail: christian.braun at tudor.lu
Resource Centre for Environmental Technologies,
Public Research Centre Henri Tudor,
6A, avenue des Hauts-Fourneaux,
L-4362 Esch-sur-Alzette, Luxembourg
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140514/3729b00a/attachment.html>
