[mapserver-users] About FILTER and FILTERITEM
Steve.Toutant at inspq.qc.ca Steve.Toutant at inspq.qc.ca
Wed May 14 06:32:56 PDT 2014
Steve, I'm using postgis and runtime variable substitution in the filter.
Should I avoid FILTER and do the runtime variable substitution in DATA?
thanks
steve
"Lime, Steve D (MNIT)" <Steve.Lime at state.mn.us>@lists.osgeo.org
Envoyé par : mapserver-users-bounces at lists.osgeo.org
2014-05-14 09:25
A
"Rahkonen Jukka  (Tike)" <jukka.rahkonen at mmmtike.fi>,
"mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
cc
Objet
Re: [mapserver-users] About FILTER and FILTERITEM
FIlters are used primarily under the hood for certain types of query
operations. The main differences are:
  - FILTERs are defined in the native query language of the underlying
driver. So for PostGIS you'd actually write a little SQL snippet.
  - FILTERs are applied when data are pulled from the underlying data
source (like a WHERE clause) and have no impact on rendering choices.
For drivers that don't have an native query capability (e.g. shapefiles)
the syntax is identical to expressions. For drivers that do have a native
query capability there really isn't much use for filters since you can
just add a where clause to the data statement.
Where I have found them useful sometimes is for simplifying class
expressions. Let's say you have a shapefile and you only want to show
features of a certain type, and then for those features you want to draw
things differently based on another attribute.
You could use logical expressions:
CLASS
  EXPRESSION ([type] = 1 AND '[attr]' = 'a')
END
CLASS
  EXPRESSION ([type] = 1 AND '[attr]' = 'b')
END
or you could use a combination of FILTER and EXPRESSIONS
FILTERITEM 'type'
FILTER '1'
CLASSITEM 'attr'
CLASS
  EXPRESSION 'a'
END
CLASS
  EXPRESSION 'b'
END
Personal preference I guess and the second option is a bit more
performant, especially in older versions. I guess my recommendation would
be avoid FILTERs unless you have a good reason to use them.
Steve
________________________________________
[mapserver-users-bounces at lists.osgeo.org] on behalf of Rahkonen Jukka
(Tike) [jukka.rahkonen at mmmtike.fi]
Sent: Wednesday, May 14, 2014 8:05 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] About FILTER and FILTERITEM
Thank you very much, Christy. By your example I made some tests and now
filters like this work for me
FILTER (([WORKERS]>20000000) OR ("[STATE_FIPS]"="17"))
The secret element was the right syntax for string attributes
("[STATE_FIPS]"="17").
Now when I know how it must be used I can find corresponding examples from
the expression page of Mapserver documentation. Could someone explain
shortly what is the difference between filter and expression? To me they
seem to do pretty similar work.
-Jukka Rahkonen-
Christy Nieman wrote:
> You do not need to set both FILTERITEM and FILTER.  You can just set
FILTER to
> an expression using as many attributes as you need. e.g.
> FILTER (( [POPULATION] < 500000 ) AND ("[DISPLAY]" == "1")). Just like
you can
> have multiple attributes in a class EXPRESSION.
> I think it's the section of the document that is key - the "MapServer
Expressions"
> section talks about using FILTER and EXPRESSION in more complex logical
> expressions, where as the section you quoted is talking about basic
string
> comparison.
> Christy
> On 14/05/14 08:03 AM, Rahkonen Jukka (Tike) wrote:
> > Hi,
> >  From document page: http://mapserver.org/mapfile/expressions.html
> > "To use a string comparison for filtering a LAYER, both FILTERITEM and
FILTER
> must be set. FILTERITEM is set to the attribute name. FILTER is set to
the value
> for comparison. The same rule applies to CLASSITEM in the LAYER object
and
> EXPRESSION in the CLASS object."
> > That would mean that only one attribute from the data can be used for
> building a filter. Is this true or just old information living in the
document?
> > -Jukka Rahkonen-
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140514/ae5a8819/attachment.html>
