[mapserver-users] Windows Installation
Jerome Villeneuve Larouche
jlarouche at mapgears.com
Wed May 14 08:49:10 PDT 2014
If you want to use OSGeo4W you should use the 32 bit installer as the
packages are more up to date on this version.
On 14-05-14 11:41 AM, trailway wrote:
> Disclaimer - I am total newbie here.
> I want to get Map Server running on my Windows 7 x64 system.
> I am aware that MS4W exists but my impression is that this project is not
> actively updated,
> i.e. it is running an old version of map server so I did not want to use it.
> Here is good
> post which describes the status:
> http://osgeo-org.1560.x6.nabble.com/Upgrading-Apache-and-PHP-that-came-with-MS4W-td5105669.html
> I started by downloading the documentation from here:
> http://mapserver.org/documentation.html
> Next I downloaded the 64 bit installer from here:
> http://trac.osgeo.org/osgeo4w/
> I then ran the installer and chose the "Express Web-GIS Install" option.
> On the "Select Packages" screen, I noticed that MapServer and GDAL were
> enabled.
> Other options such as Apache were disabled, i.e. I could not choose them.
> The installation completed without errors.
> I am able to run map server as follows:
> C:\OSGeo4W64\bin>mapserv -v
> The instructions tell me to "Run the apache-install.bat script to install
> the Apache Server".
> The thing is that I cannot find this script on my system. I ran the above
> installer again
> and chose the "Advanced Install" option. Unlike the screen shots in the
> documentation, I do not see
> Apache listed under Web (or anywhere else).
> FWIW, I do have IIS installed on my machine. I wanted to use whatever web
> server is easiest
> and works best for map server. My guess is that that is Apache. The
> instructions for "IIS Setup for MapServer" are very dated (from 2005).
> What am I doing wrong?
> Based on the things that I learn, how can I contribute to improving the
> documentation?
> View this message in context: http://osgeo-org.1560.x6.nabble.com/Windows-Installation-tp5140281.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
Jérôme Villeneuve Larouche
www.mapgears.com
