[mapserver-users] Windows Installation
trailway trailway at gmail.com
Thu May 15 12:44:23 PDT 2014
Thanks to everyone who responded.  I appreciate all the advice.
James - It is still confusing to me how exactly to configure IIS.  I have
found multiple sets of instructions.  For me, Apache is an option and I was
thinking that it might be easier to configure and use in conjunction with
Map Server.
Richard - Thanks for note on using LINUX.  Unfortunately, I have other
software which is Windows only so that isn't an option for me at this time.
I noticed on your website that you have deployed Map Server on Amazon.  If
you any lessons learned from that then I'd sure appreciate it.
After writing this I found that I had overlooked the statement "32bit/64bit
don't contain the same set of packages/versions  (compare) (purple is 32 bit
only)" on the page:
http://trac.osgeo.org/osgeo4w/
That gives you this link:
http://download.osgeo.org/osgeo4w/versions_diff-x86-x86_64.html
There are a lot of differences.
trailway at gmail dot com
View this message in context: http://osgeo-org.1560.x6.nabble.com/Windows-Installation-tp5140281p5140587.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
