[mapserver-users] msCGILoadMap(): Web application error CGI variable "map" is not set
Enrico Fiore
enricofiore80 at gmail.com
Tue May 20 06:58:45 PDT 2014
thanks for the answers.
I have solved the error closing the tag <input type="hidden" name="program"
value="/cgi-bin/mapserv"> on the inizalization file.
To change method from POST to GET don't resolve nothing if I have
understood, the difference bettween POST and GET, would be that in the
first case the attributes that you pass are visible, instread with POST
they aren't visible in the map url.
Enrico
2014-05-14 15:42 GMT+02:00 Krishna Priya Patury <krishna.patury at gmail.com>:
> You could try changing the form method from POST to GET in the
> initialization file(secondo_i.html) to see what the map value is being sent
> as.
> On Wed, May 14, 2014 at 9:29 AM, Rahkonen Jukka (Tike) <
> jukka.rahkonen at mmmtike.fi> wrote:
>> I don’t know what really fails because I have never used Mapserver this
>> way. However, the error message seems to be true.
>> When using Mapserver trough WMS the same message comes with a request
>> http://hip.latuviitta.org/cgi-bin/mapserv?service=wms&version=1.3.0&request=getcapabilities
>> If map parameter is used with an invalid value the error message is
>> different
>> http://hip.latuviitta.org/cgi-bin/mapserv?service=wms&version=1.3.0&request=getcapabilities&map=foo
>> Have a look at the code and think if the name of your mapfile really goes
>> into [map].
>> -Jukka Rahkonen-
>> Enrico Fiore wrote:
>> Sorry I have sent the first message for error, I conclude it in this post
>> the template file text is:
>> <!-- MapServer Template -->
>> <html>
>> <head><title>Seconda Mappa</title></head>
>> <body>
>> <form name="the_form" method=GET action="[program]">
>> <table width="100%">
>> <tr>
>> <td width="60%">
>> <input name="img" type="image" src="[img]"
>> width=640 height=480 order=2>
>> </td>
>> <td width="40%" align="left">
>> <table border="1" width="300">
>> <tr>
>> <td align="center" colspan=3">
>> <input type="submit" value="Ricarica">
>> </td>
>> </tr>
>> <tr>
>> <td align="center" colspan="3">Zoom</td>
>> </tr>
>> <tr>
>> <td align="right" width="100">
>> Zoom In
>> <input type=radio name=zoomdir
>> value=1 [zoom_dir_1_check]
>> </td>
>> Size
>> <input type=text name=zoomsize size=2
>> value=[zoomsize]>
>> </td>
>> </tr>
>> <tr>
>> Pan
>> value=0 [zoomdir_0_check]>
>> </td>
>> </tr>
>> </table>
>> <hr size="1">
>> <table>
>> <tr>
>> <td colspan="3">
>> <input type="checkbox" name="layer"
>> value="Regioni" [Regioni_check]>
>> Regioni
>> </td>
>> </tr>
>> <tr>
>> <td colspan="3">
>> value="Fiumi" [Fiumi_check]>
>> Fiumi
>> </td>
>> </tr>
>> <tr>
>> <td colspan="3">
>> value="Province" [Province_check]>
>> Province
>> </td>
>> </tr>
>> </table>
>> </td>
>> </tr>
>> </table>
>> <input type="hidden" name="imgxy" value="320 240">
>> <input type="hidden" name="imgext" value="[mapext]">
>> <input type="hidden" name="map" value="[map]">
>> <input type="hidden" name="program" value="[program]">
>> </form>
>> </body>
>> </html>
>> My question is what I miss in my exercise.
>> Can anyone help me?
>> And sorry for to have split the message in two post.
>> With thanks,
>> Enrico
>> 2014-05-14 14:58 GMT+02:00 Enrico Fiore <enricofiore80 at gmail.com>:
>> Hi,
>> I tried to create a simple map application whit zoom and pan
>> capabilities, following the instructions contained in the book "Beginning
>> MapServer".
>> I created a map file (secondo.map), an initialization file
>> (secondo_i.html) and a template file (secondo.html).
>> When I lunch the command
>> http://localhost/secondo_i.html
>> the browser shows this error message:
>> msCGILoadMap(): Web application error. CGI variable "map" is not set.
>> I work with Mapserver 6.4.1-2 and OS: Ubuntu 14.04
>> Text contained in initialization file:
>> <html>
>> <head><title>MapServer Seconda mappa</title></head>
>> <body>
>> <form method=POST action="/cgi-bin/mapserv">
>> <input type="submit" value="Clicca qui">
>> <input type="hidden" name="program" value="/cgi-bin/mapserv"
>> <input type="hidden" name= "map" value =
>> "/home/enrico/mapserverdata/secondo.map">
>> <input type="hidden" name="zoomsize" size=2 value=2>
>> <input type="hidden" name="layers" value="Regioni Fiumi
>> Province">
>> </form>
>> </body>
>> </html>
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140520/dff7c6d9/attachment-0001.html>
