[mapserver-users] RE Dynamically extent and layer filter
Steve.Toutant at inspq.qc.ca
Fri May 30 09:30:21 PDT 2014
Begin with a simple validation until it works. Is it working if you set
VALIDATION
id '.*'
END
If yes then the problem is in your regex. Make sure that ',' are accepted.
If not the problem is the FILTER or the parameter you pass.
Also Is your ID an integer or text in postgis? I think it matters.
('%id%') this would send a string to pg. In this case try FILTER "id" in
('%id%'), otherwise try
FILTER id in (%id%)
It is not an easy task (in my opinion) in mapserv to use expresion and
filter
But have a look at this. there are several examples
http://mapserver.org/fr/mapfile/expressions.html#string-expressions-that-return-a-logical-value
Also in you MAPFILE set debug 5 in the MAP block, and also in your layer
block. You will have more info in your mapserver log.
steve
Dedy Fuadi <sampahe.fb3 at gmail.com>
2014-05-30 12:17
A
cc
mapserver-users at lists.osgeo.org
Objet
Re: RE [mapserver-users] Dynamically extent and layer filter
This is my mapfile part :
VALIDATION
'id' '^[0-9]{1}$'
END
FILTER (id in ('%id%'))
and as your advice I set URL parameter like &id=1,4,8 but the map is not
appears there.
When I opened debug, I found :
[Sat May 31 00:10:34 2014].758000 msEvalRegex(): Regular expression error.
String failed expression test.
[Sat May 31 00:10:34 2014].758000 loadForm(): Web application error.
Parameter 'id' value fails to validate.
On Fri, May 30, 2014 at 11:42 PM, <Steve.Toutant at inspq.qc.ca> wrote:
In your mapfile you could set FILTER "id in (%ID%)" .
And in the url pass a string as parameter such as &id=1,4,8
That would be a simple way
Please post further question on mapserver list, so others can answer you,
and the answers can help other people later
thanks
steve
2014-05-30 11:28
A
cc
Objet
Hi Steve,
Your advice is nicely work for me! :D
But how to select more than one data from postgis by VALIDATION block? For
example, I have a postgis table that have 20 data, then I wanto to select
data 1,4,8, or else to display by customizing URL parameter. I set '%id%'
as my variable at mapfile, I just can display one data like &id=1.
Please for your help.
Thank you.
On Fri, May 30, 2014 at 8:30 PM, <Steve.Toutant at inspq.qc.ca> wrote:
Hi
What did you try and what happened? Something in the mapserver log.
If I understand well you want to use run time substitution, if so here a
link
http://mapserver.org/cgi/runsub.html
Make sure you have a VALIDATION block
Steve
Dedy Fuadi <sampahe.fb3 at gmail.com>@lists.osgeo.org
Envoyé par : mapserver-users-bounces at lists.osgeo.org
2014-05-30 06:52
A
cc
Objet
Hello friends,
I just success applying filter data for postgis database on my mapfile,
but I met problem when I was to try use dynamic variable for filter data
and extent map like variable at php file.
What should I do for solving this problem? Whether mapfile can be a
dynamically file like php?
Thank you,
regards._______________________________________________
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140530/1ef6ea87/attachment.html>
