[mapserver-users] Σχετ: Σχετ: Installation of Mapserver 6.4.1
Samuel Mesa
samuelmesa at gmail.com
Mon Nov 10 11:51:06 PST 2014
I understand that the Ubuntu repositories are compatible with Linux
Mint. Have you tried the following solution to install MapServer
binaries from UbuntuGIS?:
http://gis.stackexchange.com/questions/72588/how-to-install-qgis-2-0-on-mint-15?answertab=active#tab-top
For Mapserver:
sudo aptitude install python-software-properties
sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
sudo aptitude update
sudo aptitude install mapserver
El lun, 10 de nov 2014 a las 2:40 PM, Stefanos Anastasiou
<emperor_stef at yahoo.gr> escribió:
> Hi Samuel,
> I'm using Linux Mint 17. Indeed I installed all libraries through the
> repos and I presume it took care of the dependencies. And that was my
> initial qusestion actually: if i should use the synaptic or compile
> it from scratch. Probably the problem is in the paths of the
> libraries that cmake can't find them but I think the paths are the
> default paths that the synaptic installed them.
> Stefanos
> Στις 9:34 μ.μ. Δευτέρα, 10 Νοεμβρίου 2014,
> ο/η Samuel Mesa <samuelmesa at gmail.com> έγραψε:
> What distribution of Linux you are using Stefanos?. I think you could
> use a package manager to install dependencies and Mapserver.
> El lun, 10 de nov 2014 a las 1:04 PM, Stefanos Anastasiou
>> Hello Samuel..!!!
>> No I'm getting the following error:
>> CMake Error at CMakeLists.txt:49 (message):
>> GEOS library/component/dependency could not be found.
>> -- Could NOT find SVG (missing: SVG_LIBRARY SVG_INCLUDE_DIR)
>> -- Could NOT find SVGCAIRO (missing: SVGCAIRO_LIBRARY
>> SVGCAIRO_INCLUDE_DIR)
>> SVGCAIRO library/component/dependency could not be found.
>> Could NOT find GDAL (missing: GDAL_LIBRARY GDAL_INCLUDE_DIR)
>> CMake Error at CMakeLists.txt:567 (message):
>> GDAL library could not be found and is needed for OGR support.
>> Found CURL: /usr/lib/i386-linux-gnu/libcurl.so (found version
>> "7.35.0")
>> CMake Error at CMakeLists.txt:60 (message):
>> CLIENT_WMS support requires GDAL support, however GDAL support has
>> been
>> disabled.
>> CLIENT_WFS support requires OGR support, however OGR support has
>> been
>> disabled.
>> WFS support requires OGR support, however OGR support has been
>> disabled.
>> KML support requires LIBXML2 support, however LIBXML2 support has
>> been
>> disabled.
>> SOS support requires LIBXML2 support, however LIBXML2 support has
>> been
>> disabled.
>> GIF library/component/dependency could not be found.
>> CMake Error at
>> /usr/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:108
>> (message):
>> Could NOT find SWIG (missing: SWIG_EXECUTABLE SWIG_DIR)
>> Does is have to do with the compiling of the libraries? I installed
>> all libraries and their .dev through the repositories. Does it have
>> to do anything?
>> Thanks a lot.
>> Stefanos
>> Στις 10:10 μ.μ. Σάββατο, 8 Νοεμβρίου 2014,
>> ο/η "samuelmesa at gmail.com" <samuelmesa at gmail.com> έγραψε:
>> Try again decompressing the src and ignore step 2:
>> 2. rm CMakeCache.txt CMakeFiles
>> regards,
>> Samuel Mesa.
>> 2014-11-08 14:31 GMT-05:00 Stefanos Anastasiou
>> <emperor_stef at yahoo.gr>:
>>> Hi Samuel,
>>> Thank you for the reply..!!! I'm getting the following error :
>>> CMake Error: The source directory
>>> "/usr/local/src/mapserver-6.4.1/build" does not appear to contain
>>> CMakeLists.txt.
>>> Specify --help for usage, or press the help button on the CMake GUI.
>>> If I use CMake GUI I get permission error. I've placed the folder
>>> in /usr/local/src. What should I do ?
>>> Stefanos
>>> Στις 3:12 π.μ. Πέμπτη, 6 Νοεμβρίου 2014, ο/η
>>> Hi Stefanos, the next is the instructions for compiling Mapserver
>>> in Arch Linux [1]:
>>> 1. cd to src mapserver
>>> 3. mkdir build
>>> 4. cd build
>>> 5. compiling as:
>>> cmake .. -DCMAKE_INSTALL_PREFIX=/usr
>>> -DPYTHON_EXECUTABLE=/usr/bin/python2 \
>>> -DPYTHON_LIBRARIES=/usr/lib/python2.7 \
>>> -DPYTHON_INCLUDE_PATH=/usr/include/python2.7 \
>>> -DFRIBIDI_INCLUDE_DIR="/usr/include/glib-2.0;/usr/lib/glib-2.0/include;/usr/include/fribidi"
>>> -DWITH_CAIRO=ON \
>>> -DWITH_CLIENT_WFS=ON \
>>> -DWITH_CLIENT_WMS=ON \
>>> -DWITH_CSHARP=OFF \
>>> -DWITH_CURL=ON \
>>> -DWITH_EXEMPI=OFF \
>>> -DWITH_FCGI=ON \
>>> -DWITH_FRIBIDI=ON \
>>> -DWITH_GD=OFF \
>>> -DWITH_GDAL=ON \
>>> -DWITH_GENERIC_NINT=OFF \
>>> -DWITH_GEOS=ON \
>>> -DWITH_GIF=ON \
>>> -DWITH_ICONV=ON \
>>> -DWITH_JAVA=OFF \
>>> -DWITH_KML=ON \
>>> -DWITH_LIBXML2=ON \
>>> -DWITH_MSSQL2008=OFF \
>>> -DWITH_MYSQL=OFF \
>>> -DWITH_OGR=ON \
>>> -DWITH_ORACLESPATIAL=OFF \
>>> -DWITH_ORACLE_PLUGIN=OFF \
>>> -DWITH_PERL=OFF \
>>> -DWITH_PHP=ON \
>>> -DWITH_POINT_Z_M=OFF \
>>> -DWITH_POSTGIS=ON \
>>> -DWITH_PROJ=ON \
>>> -DWITH_PYTHON=ON \
>>> -DWITH_RSVG=OFF \
>>> -DWITH_RUBY=OFF \
>>> -DWITH_SDE=OFF \
>>> -DWITH_SDE_PLUGIN=OFF \
>>> -DWITH_SOS=ON \
>>> -DWITH_SVGCAIRO=ON \
>>> -DWITH_THREAD_SAFETY=ON \
>>> -DWITH_WCS=ON \
>>> -DWITH_WFS=ON \
>>> -DWITH_WMS=ON \
>>> -DWITH_XMLMAPFILE=OFF \
>>> -DFREETYPE_INCLUDE_DIR=/usr/include/freetype2 \
>>> 6. make clean && make
>>> 7. make install
>>> regards,
>>> Samuel Mesa.
>>> [1] https://aur.archlinux.org/packages/ma/mapserver/PKGBUILD
>>> 2014-11-04 17:44 GMT-05:00 Stefanos Anastasiou
>>>> Hello.!!
>>>> I'm wondering if the installation should be made only with cmake.
>>>> Can't someone just use the repos ? I'm trying to use cmake but
>>>> getting a lot or errors, probably having to do with the PREFIX
>>>> path. So I'm feeling pretty confused. I'm also not that good with
>>>> linux file system hierarchy.
>>>> Thanks
>>>> Stefanos
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> / v \
>> / v \
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141110/254849e5/attachment-0001.html>
