[mapserver-users] MapServer SOS setup questions
Brent Wood
pcreso at pcreso.com
Thu Nov 27 22:18:33 PST 2014
Mapservers SOS implementation is pretty minimal these days.
You might look at 52N for their FOSS SOS server. You can either harvest you data into the internal db, or use Hibernate to build a middleware tool that can access your db directly.
Brent Wood
From: Carsen Banister <carsen.banister at gmail.com>
To: mapserver-users at lists.osgeo.org
Sent: Tuesday, November 25, 2014 2:50 PM
Subject: [mapserver-users] MapServer SOS setup questions
<!--#yiv9641486375 _filtered #yiv9641486375 {font-family:"Cambria Math";panose-1:2 4 5 3 5 4 6 3 2 4;} _filtered #yiv9641486375 {font-family:Calibri;panose-1:2 15 5 2 2 2 4 3 2 4;}#yiv9641486375 #yiv9641486375 p.yiv9641486375MsoNormal, #yiv9641486375 li.yiv9641486375MsoNormal, #yiv9641486375 div.yiv9641486375MsoNormal {margin:0cm;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", sans-serif;}#yiv9641486375 a:link, #yiv9641486375 span.yiv9641486375MsoHyperlink {color:#0563C1;text-decoration:underline;}#yiv9641486375 a:visited, #yiv9641486375 span.yiv9641486375MsoHyperlinkFollowed {color:#954F72;text-decoration:underline;}#yiv9641486375 p {margin-right:0cm;margin-left:0cm;font-size:12.0pt;font-family:"Times New Roman", serif;}#yiv9641486375 p.yiv9641486375MsoListParagraph, #yiv9641486375 li.yiv9641486375MsoListParagraph, #yiv9641486375 div.yiv9641486375MsoListParagraph {margin-top:0cm;margin-right:0cm;margin-bottom:0cm;margin-left:36.0pt;margin-bottom:.0001pt;font-size:11.0pt;font-family:"Calibri", sans-serif;}#yiv9641486375 span.yiv9641486375EmailStyle17 {font-family:"Calibri", sans-serif;color:windowtext;}#yiv9641486375 .yiv9641486375MsoChpDefault {font-family:"Calibri", sans-serif;} _filtered #yiv9641486375 {margin:72.0pt 72.0pt 72.0pt 72.0pt;}#yiv9641486375 div.yiv9641486375WordSection1 {}#yiv9641486375 _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {} _filtered #yiv9641486375 {}#yiv9641486375 ol {margin-bottom:0cm;}#yiv9641486375 ul {margin-bottom:0cm;}-->Hi, I would appreciate any help on some items associated with setting up MapServer SOS. I am quite new to MapServer, and am trying to get up to speed as quickly as possible. The reason for using MapServer’s SOS is that the database structure is custom and I’m not aware of any other SOS servers that support custom MySQL databases (if you can point me in a direction easier than MapServer, please do!). So, the questions I am hoping to get clarification on are: 1. How do you connect different layers together? e.g. layer and sublayer. What is the syntax for that in the mapfile? 2. Is there a way to dynamically generate layers (e.g. from database query result), or does the layer structure have to be hardcoded? 3. When you do a GetObservation, how do you set up MapServer so that that request pulls data from the database, e.g. OVF file configuration? Thanks in advance for any assistance. Best regards,Carsen
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141128/91bcef68/attachment.html>
