[mapserver-users] Fwd: All map services display pink tiles
Sithila Konara sithilamadushanka at gmail.com
Wed Oct 1 00:50:37 PDT 2014
<http://gis.stackexchange.com/questions/115709/all-map-services-display-pink-tiles#>
I have implemented mapserver in Ubuntu 14.04 with postgresql 9.3, postgis
and imposm using GitHub tutorial
<https://github.com/mapserver/mapserver/wiki/Rendering-OSM-data-on-Ubuntu-12.04>.
After completing the tutorial all map services display pink tiles not map
info. i was not encounter with any issues during the tutorial run. any
reason to this?
Following screenshots for your reference.
[image: enter image description here] [image: enter image description
here] [image:
When I check network I saw some errors as follows it shows as bad gate way
and internal server error [image: enter image description here]
here's my basemap makefile and mapcache.xml file
   - *basemap/makefile*
UNAME := $(shell uname)
ifeq ($(UNAME), Darwin)
SED=sed -i ""else
SED=sed -i
endif
CPP=gcc -E -x c#if the preprocessor fails for some reason, try
replacing this with "cpp" on linux, or "cpp-4.2" on darwin (not
available starting with mountain lion)
OSM_PREFIX=osm_new_
OSM_NAME_COLUMN=name
OSM_SRID=4326
OSM_UNITS=dd
OSM_EXTENT=-180 -90 180 90
OSM_SRID=3857
OSM_UNITS=meters
OSM_DB_CONNECTION=host=localhost dbname=osm user=osm password=osm port=5432
OSM_EXTENT=-20000000 -20000000 20000000 20000000
OSM_WMS_SRS=EPSG:900913 EPSG:4326 EPSG:3857 EPSG:2154 EPSG:310642901
EPSG:4171 EPSG:310024802 EPSG:310915814 EPSG:310486805 EPSG:310702807
EPSG:310700806 EPSG:310547809 EPSG:310706808 EPSG:310642810
EPSG:310642801 EPSG:310642812 EPSG:310032811 EPSG:310642813 EPSG:2986
DEBUG=1
LAYERDEBUG=1
STYLE=google#can also use google or bing
   - *mapcache-osm.xml*
<?xml version="1.0" encoding="UTF-8"?><!-- see the accompanying
https://github.com/mapserver/mapcache/blob/master/mapcache.xml.sample
for a fully commented configuration file --><mapcache><cache
name="disk" type="disk">
    <base>/home/sithila/osm-demo/mapcache/cache</base> <!-- Change Path here -->
    <symlink_blank/></cache>
<source name="osm" type="wms">
    <getmap>
        <params>
            <FORMAT>image/png</FORMAT>
            <LAYERS>default</LAYERS>
            <MAP>/home/sithila/osm-demo/basemaps/osm-google.map</MAP>
        </params>
    </getmap>
    <http>
        <url>http://localhost/cgi-bin/mapserv?</url> <!-- Change server here -->
    </http></source><tileset name="osm">
    <metadata>
        <title>OSM MapServer served map</title>
        <abstract>see
https://github.com/mapserver/mapserver/wiki/RenderingOsmDataUbuntuv2</abstract>
    </metadata>
    <source>osm</source>
    <cache>disk</cache>
    <grid>WGS84</grid>
    <grid>g</grid>
    <format>PNG</format>
    <metatile>5 5</metatile>
    <metabuffer>10</metabuffer>
    <expires>10000</expires>
    <auto_expire>86400</auto_expire>  </tileset>
<default_format>JPEG</default_format>
<service type="wms" enabled="true">
    <full_wms>assemble</full_wms>
    <resample_mode>bilinear</resample_mode>
    <format>JPEG</format>
    <maxsize>4096</maxsize></service>
<service type="wmts" enabled="true"/><service type="tms"
enabled="true"/><service type="kml" enabled="true"/><service
type="gmaps" enabled="true"/><service type="ve"
enabled="true"/><service type="demo" enabled="true"/>
<errors>report</errors><lock_dir>/tmp</lock_dir></mapcache>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141001/59db5ba6/attachment.html>
