[mapserver-users] Fwd: All map services display pink tiles
Sithila Konara
sithilamadushanka at gmail.com
Wed Oct 1 10:01:32 PDT 2014
Out put as follows...
<?xml version='1.0' encoding="UTF-8" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM "
http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
<![CDATA[
wms request for tileset osm returned an unsupported format:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>404 Not Found</title>
</head><body>
<h1>Not Found</h1>
<p>The requested URL /cgi-bin/mapserv was not found on this server.</p>
<hr>
<address>Apache/2.4.7 (Ubuntu) Server at localhost Port 80</address>
</body></html>
</ServiceException>
On Wed, Oct 1, 2014 at 6:45 PM, thomas bonfort <thomas.bonfort at gmail.com>
wrote:
> from a terminal, type:
> curl '
> http://localhost/mapcache/?LAYERS=osm&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-135,22.5,-112.5,45&WIDTH=256&HEIGHT=256
> thomas
> On 1 October 2014 18:38, Sithila Konara <sithilamadushanka at gmail.com>
> wrote:
>> hi,
>> Following URL is a one of my image URL
>> This is how errors get occors
>> [image: Inline image 1]
>> and i have examined Apache error logs, but unable find much details. I'm
>> working in a Ubuntu server in a VM environment. server is directly
>> connected to internet using NAT interface to get the Internet. But i think
>> server should provide tiles from only using local resources, after
>> successful mapserver implementation. But I noticed that pink tiles also not
>> display when i disconnect the server from the Internet. I'm new to Linux
>> and Mapserver so difficult to extract meaning of error logs etc
>> [image: Inline image 2]
>> On Wed, Oct 1, 2014 at 2:52 PM, thomas bonfort <thomas.bonfort at gmail.com>
>> wrote:
>>> Sithila,
>>> try right clicking on one of the pink tiles to open it in a new browser
>>> window, or alternately look in your apache access/error logs. You should
>>> get an error message that should give you a head start. 502 errors are
>>> usually a sign that the source wms server is producing an error instead of
>>> an image, the actual error message should be returned back to you.
>>> thomas
>>> On 1 October 2014 09:50, Sithila Konara <sithilamadushanka at gmail.com>
>>> wrote:
>>>> <http://gis.stackexchange.com/questions/115709/all-map-services-display-pink-tiles#>
>>>> I have implemented mapserver in Ubuntu 14.04 with postgresql 9.3,
>>>> postgis and imposm using GitHub tutorial
>>>> <https://github.com/mapserver/mapserver/wiki/Rendering-OSM-data-on-Ubuntu-12.04>.
>>>> After completing the tutorial all map services display pink tiles not map
>>>> info. i was not encounter with any issues during the tutorial run. any
>>>> reason to this?
>>>> Following screenshots for your reference.
>>>> [image: enter image description here] [image: enter image description
>>>> here] [image: enter image description here]
>>>> When I check network I saw some errors as follows it shows as bad gate
>>>> way and internal server error [image: enter image description here]
>>>> here's my basemap makefile and mapcache.xml file
>>>> - *basemap/makefile*
>>>> UNAME := $(shell uname)
>>>> ifeq ($(UNAME), Darwin)
>>>> SED=sed -i ""else
>>>> SED=sed -i
>>>> endif
>>>> CPP=gcc -E -x c#if the preprocessor fails for some reason, try replacing this with "cpp" on linux, or "cpp-4.2" on darwin (not available starting with mountain lion)
>>>> OSM_PREFIX=osm_new_
>>>> OSM_NAME_COLUMN=name
>>>> OSM_SRID=4326
>>>> OSM_UNITS=dd
>>>> OSM_EXTENT=-180 -90 180 90
>>>> OSM_SRID=3857
>>>> OSM_UNITS=meters
>>>> OSM_DB_CONNECTION=host=localhost dbname=osm user=osm password=osm port=5432
>>>> OSM_EXTENT=-20000000 -20000000 20000000 20000000
>>>> OSM_WMS_SRS=EPSG:900913 EPSG:4326 EPSG:3857 EPSG:2154 EPSG:310642901 EPSG:4171 EPSG:310024802 EPSG:310915814 EPSG:310486805 EPSG:310702807 EPSG:310700806 EPSG:310547809 EPSG:310706808 EPSG:310642810 EPSG:310642801 EPSG:310642812 EPSG:310032811 EPSG:310642813 EPSG:2986
>>>> DEBUG=1
>>>> LAYERDEBUG=1
>>>> STYLE=google#can also use google or bing
>>>> - *mapcache-osm.xml*
>>>> <?xml version="1.0" encoding="UTF-8"?><!-- see the accompanying https://github.com/mapserver/mapcache/blob/master/mapcache.xml.sample for a fully commented configuration file --><mapcache><cache name="disk" type="disk">
>>>> <base>/home/sithila/osm-demo/mapcache/cache</base> <!-- Change Path here -->
>>>> <symlink_blank/></cache>
>>>> <source name="osm" type="wms">
>>>> <getmap>
>>>> <params>
>>>> <FORMAT>image/png</FORMAT>
>>>> <LAYERS>default</LAYERS>
>>>> <MAP>/home/sithila/osm-demo/basemaps/osm-google.map</MAP> <!-- Change Path here -->
>>>> </params>
>>>> </getmap>
>>>> <http>
>>>> <url>http://localhost/cgi-bin/mapserv?</url> <!-- Change server here -->
>>>> </http></source><tileset name="osm">
>>>> <metadata>
>>>> <title>OSM MapServer served map</title>
>>>> <abstract>see https://github.com/mapserver/mapserver/wiki/RenderingOsmDataUbuntuv2</abstract>
>>>> </metadata>
>>>> <source>osm</source>
>>>> <cache>disk</cache>
>>>> <grid>WGS84</grid>
>>>> <grid>g</grid>
>>>> <format>PNG</format>
>>>> <metatile>5 5</metatile>
>>>> <metabuffer>10</metabuffer>
>>>> <expires>10000</expires>
>>>> <auto_expire>86400</auto_expire> </tileset>
>>>> <default_format>JPEG</default_format>
>>>> <service type="wms" enabled="true">
>>>> <full_wms>assemble</full_wms>
>>>> <resample_mode>bilinear</resample_mode>
>>>> <format>JPEG</format>
>>>> <maxsize>4096</maxsize></service>
>>>> <service type="wmts" enabled="true"/><service type="tms" enabled="true"/><service type="kml" enabled="true"/><service type="gmaps" enabled="true"/><service type="ve" enabled="true"/><service type="demo" enabled="true"/>
>>>> <errors>report</errors><lock_dir>/tmp</lock_dir></mapcache>
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141001/4480faa2/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141001/4480faa2/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20141001/4480faa2/attachment-0003.png>
