[mapserver-users] Leaflet + OpenMap + Mapserver WMS
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu Sep 25 05:52:30 PDT 2014
On 2014-09-25 8:28 AM, Burgholzer, Robert (DEQ) wrote:
> Running afoul of projections conflict in the setup with the following error:
> "msWMSLoadGetMapParams(): WMS server error. Invalid SRS given : SRS must be valid for all requested layers."
> All layers in my Mapfile have an EPSG of 4326, but the base layer of my map in Leaflet is OpenMap which I understand comes in with the google projection 900913?
> I have done the following:
> * I added the def for 900913 to the proj4 epsg file (this def was added after compiling mapserver but can't imagine that would matter?): /usr/share/proj/epsg
> * Compiled Mapserver with proj4 enabled (--with-proj4)
> * Set allowable 900913, 4326, and 4269 in my mapfile projection block (block shown below)
> * Set "debug 5" in my mapfile but received no other info about this issue (like what proj is being requested by Leaflet)
> Mapfile excerpts:
> PROJECTION
> "init=epsg:900913"
> "init=epsg:4269"
> "init=epsg:4326"
> END
Robert, as Mike said, you are declaring your projections wrong. Best
way to learn how is to follow an example mapfile:
http://mapserver.org/ogc/wms_server.html#sample-wms-server-mapfile
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
