[mapserver-users] Installing MapServer with FastCGI
jdmorgan jdmorgan at unca.edu
Thu Sep 25 09:26:43 PDT 2014
Hi Francesco,
You were right and I needed to do a /yum install fcgi-devel/
Thanks so much for your help.
Derek
On 9/25/2014 11:58 AM, Francesco Pirotti - UNIPD wrote:
> Did you install the fast-cgi *development *files? I think you
> installed the apache fcgi module, but not the dependencies so
> mapserver compilation is missing the header files.
> Something like:
> /apt/-/get/install libfcgi-/dev
> /should work for installing the required dependencies.
> Google a bit for that.
> Cheers,
> Francesco
> *FRANCESCO PIROTTI *
> *CIRGEO Interdepartmental Research Center in Geomatics *
> *TESAF Department of Land, Environment, Agriculture and Forestry *
> Università di Padova
> Via dell'Università, 16
> 35020 -- Legnaro (PD),Italy
> Tel: +39 049 827 2710
> Cell.: +39 392 395 2067
> Email: francesco.pirotti at unipd.it <mailto:francesco.pirotti at unipd.it>
> Skype: francesco197576
> Web: http://www.cirgeo.unipd.it/fp
> Il 25/09/2014 16:55, jdmorgan ha scritto:
>> Hello,
>> I am trying to compile a version of MapServer 6.4.1. on CentOS 6.
>> I am at the part where I am doing a CMAKE. I have installed FastCGI
>> already however (following
>> http://linuxwave.blogspot.com/2010/08/installing-apache-modfastcgifastcgi.html).
>> However, I am not really sure where it installed which brings me to
>> my issue.
>> Currently here is the error I get when running the CMAKE:
>> /CMake Error at CMakeLists.txt:49 (message):/
>> /FCGI library/component/dependency could not be found./
>> /HINTS:/
>> /- disable FCGI support by adding -DWITH_FCGI=0/
>> /- add the FCGI install directory to the CMAKE_PREFIX_PATH variable
>> (-DCMAKE_PREFIX_PATH="/path/to/FCGI-install-dir;/path/to/other/dirs"/
>> /Call Stack (most recent call first):/
>> /CMakeLists.txt:482 (report_optional_not_found)/
>> I have tried in my CMAKE script to point to where I think that FCGI
>> (FastCGI) is but this doesn't seem to be working for me.Anyone out
>> there have success with this type of thing that can point me in the
>> right direction?
>> Thanks,
>> Derek
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
John Derek Morgan, PhD
UNC Asheville's
National Environmental Modeling and Analysis Center (NEMAC)
http://nemac.unca.edu
828-258-7660
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140925/ff79e5f5/attachment-0001.html>
Name: not available
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20140925/ff79e5f5/attachment-0001.jpe>
