[mapserver-users] Fwd: Ubuntu Trusty, MapServer 6.4.1, Gdal 1.11
Marco Afonso mafonso333 at gmail.com
Sat Apr 11 04:35:40 PDT 2015
One last note...
When requesting the mapfile thought cgi-bin/mapserv it was working!
But we are requesting the WMS through PHP mapscript (for a number of
reasons) so... my guess is that after compiling gdal with ecw I should had
reboot apache so it could reload the new gdal version :)
Thank you Jukka, Richard and Jeff for your help :)
2015-04-11 12:23 GMT+01:00 Marco Afonso <mafonso333 at gmail.com>:
> Reboot and... voilá! It is working! :)
> Cheers
> 2015-04-11 12:02 GMT+01:00 Rahkonen Jukka (MML) <
> jukka.rahkonen at maanmittauslaitos.fi>:
>>  So does it work with one tiff on Linux? If yes the file access theory
>> is wrong.
>> Jukka
>> Lähettäjä: Marco Afonso <mafonso333 at gmail.com>
>> Lähetetty: ‎11.‎4.‎2015 13:57
>> Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
>> Kopio: mapserver <mapserver-users at lists.osgeo.org>
>> Aihe: Re: [mapserver-users] Ubuntu Trusty, MapServer 6.4.1, Gdal 1.11
>>  Hi Jukka,
>>  We have exactly the same MS configuration, shapefile and ECW files
>> working a older windows machine, so it seems to me that it is something to
>> do with ms on linux.
>>  As I stated before, gdalinfo and ogrinfo are reading corretly the
>> shapefile and ecw files throught command line.
>>  What file permitions would be required?
>>  Thanks
>> 2015-04-11 11:21 GMT+01:00 Rahkonen Jukka (MML) <
>>>  Hi,
>>> About how to test I have only one advice: Do it systematically.
>>> Being systematically means building something pretty simple that works
>>> first and add new stuff one and only one step at a time. Somehow like:
>>> Problem is that ECW layer through tileindex does not work.
>>> 1.)    Does it work with one ECW? It did not, you fixed the build and
>>> gdalinfo is OK now but did you also test that MapServer is now OK with one
>>> ECW?
>>> 2.)    If it is working with ECW then good.  If it is not, make an
>>> additional test by converting one  ECW into GeoTIFF and test your layer
>>> with it. If it is OK there is still something wrong with ECW support. If
>>> GeoTIFF does not work there is something else wrong and you must fix it
>>> before you can even know if the issue has to do with ECW at all.
>>> 3.)     If one GeoTIFF and one ECW is OK then perhaps something is
>>> wrong with the tileindex. Make a new tileindex that contains a) only that
>>> one GeoTIFF you created in step 2 b) the same for the one original ECW. Do
>>> they work?
>>> Test with the file
>>> /home/mapas/dados/raster/ortos2012/006003Argb_12_d73.ecw. Does it exist? Is
>>> it empty? Can’t it be accessed due to wrong path or missing rights?
>>> (): Unable to access file. Corrupt, empty or missing file
>>> '/home/mapas/dados/raster/ortos2012/006003Argb_12_d73.ecw' for
>>> layer 'ortos2012'.
>>> As a general rule, add DEBUG 5 into your layer when debugging, and I
>>> suggest to add always PROJECTION blocks into MAP and LAYER level.
>>> -Jukka Rahkonen-
>>> *Lähettäjä:* mapserver-users-bounces at lists.osgeo.org [mailto:
>>> mapserver-users-bounces at lists.osgeo.org] *Puolesta *Marco Afonso
>>> *Lähetetty:* 10. huhtikuuta 2015 17:25
>>> *Vastaanottaja:* Jeff McKenna
>>> *Kopio:* mapserver
>>> *Aihe:* Re: [mapserver-users] Ubuntu Trusty, MapServer 6.4.1, Gdal 1.11
>>> Hi again,
>>> Ok Jeff, I can change if I find something new.
>>> Not solved yet :p
>>> Ok, recompiled libecwj2 and gdal. gdalinfo is now reading the ecw
>>> correctly.
>>> But I still get the mapserver error... are there any further tests that
>>> I can do?
>>> Thanks.
>>> 2015-04-10 15:07 GMT+01:00 Jeff McKenna <jmckenna at gatewaygeomatics.com>:
>>> On 2015-04-10 10:34 AM, Marco Afonso wrote:
>>> Found this
>>> And reading moreover on http://trac.osgeo.org/gdal/wiki/ECW
>>> Those wiki pages are wonderful; please as you head down this path don't
>>> be afraid to update that ECW build wiki with any notes or changes you
>>> noticed.  Thanks!
>>> -jeff
>>> Jeff McKenna
>>> MapServer Consulting and Training Services
>>> http://www.gatewaygeomatics.com/
>>> mapserver-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> Regards,
>>> Marco Afonso
>>> http://goo.gl/ZDtQjm
>>  Regards,
>> Marco Afonso
> Regards,
> Marco Afonso
Regards,
Marco Afonso
Regards,
Marco Afonso
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20150411/91eb992a/attachment-0001.html>
