[mapserver-users] mapserver 6.4.1 - special characters in legend
Jörg Thomsen jt at mapmedia.de
Wed Apr 15 03:53:46 PDT 2015
- be sure use a ttf for the labeling of your legend
- use the encoding key within the label-block of your legend-block
- safe your mapfile with the correct encoding -> the same you define in
the mapfile
It has nothing to do with the apache encoding, because mapserver creates
the legend-graphic, apache only serves the raster-file.
I hope it helps, Jörg
Am 15.04.2015 um 12:36 schrieb Carmen Delia Hernández Pérez:
> Hi!
> I am installing Mapserver 6.4.1 on CentOS 7 for publish  WMS services. I
> have been installing all dependencies and I compiled mapserver.
> Mapserver works. The WMS services work well except with legends
> generation . In layers with one special character ( accent, ñ ) in its
> title, legend is wrong.
> For example:
> LAYER
>                           NAME "Campos_futbol"
>                           STATUS ON
>                           METADATA
>                                        "ows_title"          "Campos de
> fútbol"
> When I do one GetLegendGraphic query it returns "Campos de f.tbol" in
> layer description because the "u character  accented" is wrong.
> I don´t know where is the problem because when I do one GetFeatureInfo
> query  or  one GetCapabilities query,  these characters are show
> correctly. My apache has  ISO-8859-1 encoding by default.
> GetFeatureInfo results:
> Layer 'Campos_futbol'
>   Feature 38:
>     NOMBRE = 'Campo de Fútbol de La Matanza'
> GetCapabilities results:
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <Layer queryable="1" opaque="0" cascaded="0">
> <Name>Campos_futbol</Name>
> <Title>Campos de fútbol</Title>
> *Someone has idea where can be the problem? Can it be I have some
> library incorrect?*
> My Mapserver  is configured so:
> # mapserv -v
> MapServer version 6.4.1 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI
> SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER SUPPORTS=WCS_SERVER INPUT=JPEG
> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> Thanks in advance!!
> Carmen
> mapserver-users at lists.osgeo.org
