[mapserver-users] Some queries return blank Images
EdouardG
edouard.giudice at gmail.com
Wed Aug 12 04:32:21 PDT 2015
First, thank you for this quick answer. I have been struggling quite a bit
with this.
I agree with you on the projection problem, the error made me think that at
first. The problem is all my data is in EPSG 4326 and all the request are in
this CRS too. So I would think no reprojection is necessary.
My mapfile is as follow :
MAP
NAME "Pipes_Angola_WMS"
EXTENT 11.660069 -7.637100 11.665110 -7.622088
PROJECTION
"init=epsg:4326"
END
OUTPUTFORMAT
NAME "GTiff"
DRIVER GDAL/GTiff
MIMETYPE "image/tiff"
IMAGEMODE RGB
EXTENSION "tif"
END
CONFIG "MS_ERRORFILE" "/data_local/mapdata/ms_error.txt"
WEB
METADATA
"wms_title" "Pipes Angola Server"
"wms_onlineresource" "http://10.57.168.114/wms"
"wms_srs" "EPSG:4326"
"wms_enable_request" "*"
END
END
LAYER
NAME "Pipes_Layer"
STATUS ON
TYPE RASTER
DEBUG 5
TILEINDEX "/data_local/mapdata/data/index.shp"
TILEITEM "location"
METADATA
"wms_title" "WMS Pipe Angola"
END
PROJECTION
"init=epsg:4326"
END
END
END
The requests I used in my browser where "cutomised" from those I found in
the log made by WolrdWind and Arcmap :
/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&CRS=EPSG:4326&BBOX=-7.6344002188000681,11.660860157323178,-7.6343547473002458,11.660909269398337&WIDTH=1376&HEIGHT=1274&LAYERS=Pipes_Layer&STYLES=&EXCEPTIONS=XML&FORMAT=image/png&BGCOLOR=0xFEFFFF&TRANSPARENT=TRUE
The result of this request is an image cointaining a working image and a
ghost image also.
I tried gdalinfo on a working and not working image and i got :
for a working image :
Driver: GTiff/GeoTIFF
Files: 20141215-161415.338-026880.tif
Size is 1633, 1431
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
Origin = (11.660858092114065,-7.634358707092891)
Pixel Size = (0.000000031665310,-0.000000031665310)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 11.6608581, -7.6343587) ( 11d39'39.09"E, 7d38' 3.69"S)
Lower Left ( 11.6608581, -7.6344040) ( 11d39'39.09"E, 7d38' 3.85"S)
Upper Right ( 11.6609098, -7.6343587) ( 11d39'39.28"E, 7d38' 3.69"S)
Lower Right ( 11.6609098, -7.6344040) ( 11d39'39.28"E, 7d38' 3.85"S)
Center ( 11.6608839, -7.6343814) ( 11d39'39.18"E, 7d38' 3.77"S)
Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
Minimum=84.000, Maximum=255.000, Mean=128.986, StdDev=9.596
NoData Value=0
Overviews: 817x716, 409x358, 205x179, 103x90, 52x45, 26x23, 13x12
Metadata:
STATISTICS_MAXIMUM=255
STATISTICS_MEAN=128.98649616133
STATISTICS_MINIMUM=84
STATISTICS_STDDEV=9.5962094258965
for a not working image :
Files: 20141215-161416.853-026881.tif
Size is 1633, 1430
GEOGCS["WGS 84",
DATUM["WGS_1984",
Origin = (11.660866469734488,-7.634335714785948)
Pixel Size = (0.000000031279575,-0.000000031279575)
Metadata:
AREA_OR_POINT=Area
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 11.6608665, -7.6343357) ( 11d39'39.12"E, 7d38' 3.61"S)
Lower Left ( 11.6608665, -7.6343804) ( 11d39'39.12"E, 7d38' 3.77"S)
Upper Right ( 11.6609175, -7.6343357) ( 11d39'39.30"E, 7d38' 3.61"S)
Lower Right ( 11.6609175, -7.6343804) ( 11d39'39.30"E, 7d38' 3.77"S)
Center ( 11.6608920, -7.6343581) ( 11d39'39.21"E, 7d38' 3.69"S)
Minimum=79.000, Maximum=219.000, Mean=126.598, StdDev=10.897
NoData Value=0
Overviews: 817x715, 409x358, 205x179, 103x90, 52x45, 26x23, 13x12
Metadata:
STATISTICS_MAXIMUM=219
STATISTICS_MEAN=126.59779535671
STATISTICS_MINIMUM=79
STATISTICS_STDDEV=10.897325852031
The differences are in the pixel size and the dimensions of the image itself
but others with other pixel values and dimensions work perfectly fine.
Mapserver seems to digest those differences for some cases but not for
others...
An otherthing I forgot to tell you is that there is some kind of pattern in
thoses holes. I am supposed to get a coninuous line of pictures overlapping
but the holes are not random, I have something like 5 holes made by
continuous images (which number can be different). But from the survey log,
the two images i pasted the gdalinfo about where taken 1 minute appart...
I hope you have everything you need .
View this message in context: http://osgeo-org.1560.x6.nabble.com/Some-queries-return-blank-Images-tp5219503p5219514.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
