[mapserver-users] CGI Tilemode blank on one layer
Daniel Mwaurah
mwaurah at gmail.com
Wed Dec 23 12:27:29 PST 2015
hallo people,
I would greatly appreciate some help with Mapserver Tile mode. Eeven a hint
in the right direction would be much appreciated. I am trying to display
two layers in Tile mode in open layers as follows
1.
http://localhost/cgi-bin/mapserv?MAP=/var/wpsinput/gdss.map&layer=kenyaoutline&mode=tile&tile=${x}+${y}+${z}.png
2.
http://localhost/cgi-bin/mapserv?MAP=/var/wpsinput/gdss.map&layer=10m_ocean&mode=tile&tile=${x}+${y}+${z}.png
The problem arises in that one layer the 10m_ocean displays while the other
one just shows a blank. I suspect it has to do with the extents because the
10m_ocean layers has a large extent from -180 to 180 while the kenyaoutline
layer only covers one country from about 33 to 37 degrees.
Is there a limitation to small extents in tile mode? or what could be the
problem. My mapfile is as below.
MAP
#FONTSET "[fontsetpath]"
DEBUG 5
CONFIG "MS_ERRORFILE" "/var/www/wpsinput/ms_error.txt"
EXTENT 33 -5 42 6
IMAGETYPE "png"
NAME "Natural_Earth_quick_start_for_QGIS"
SIZE 600 600
CONFIG ON_MISSING_DATA "LOG"
STATUS ON
UNITS DD
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "AGG/PNG"
EXTENSION "png"
IMAGEMODE RGBA
TRANSPARENT TRUE
END # OUTPUTFORMAT
PROJECTION
"proj=longlat"
"datum=WGS84"
"no_defs"
END # PROJECTION
LEGEND
KEYSIZE 20 10
KEYSPACING 5 5
LABEL
SIZE MEDIUM
OFFSET 0 0
SHADOWSIZE 1 1
TYPE BITMAP
END # LABEL
STATUS OFF
END # LEGEND
QUERYMAP
SIZE -1 -1
STATUS OFF
STYLE HILITE
END # QUERYMAP
SCALEBAR
INTERVALS 4
LABEL
SIZE MEDIUM
OFFSET 0 0
SHADOWSIZE 1 1
TYPE BITMAP
END # LABEL
SIZE 200 3
STATUS OFF
UNITS MILES
END # SCALEBAR
WEB
FOOTER ""
HEADER ""
TEMPPATH ""
METADATA
"ows_onlineresource" "
http://localhost/cgi-bin/mapserv?map=/home/wpsinput/worldmap.map"
"ows_enable_request" "*"
"ows_srs" "EPSG:4326"
"ows_title" "Natural_Earth_quick_start_for_QGIS"
END # METADATA
#TEMPLATE "[templatepath]"
END # WEB
LAYER
DATA "/var/www/10m_physical/10m_ocean.shp"
EXTENT 33 -5 42 6
METADATA
"ows_title" "10m_ocean"
END # METADATA
NAME "10m_ocean"
PROJECTION
"proj=longlat"
"datum=WGS84"
"no_defs"
END # PROJECTION
STATUS ON
TILEITEM "location"
TYPE POLYGON
UNITS METERS
CLASS
NAME "Single symbol"
STYLE
COLOR 198 226 242
END # STYLE
END # CLASS
END # LAYER
LAYER
DATA "/var/www/kenyaoutline/Kenyaoutline.shp"
EXTENT 33 -5 42 6
METADATA
"ows_title" "Kenyaoutline"
END # METADATA
NAME "Kenyaoutline"
PROJECTION
"proj=longlat"
"datum=WGS84"
"no_defs"
END # PROJECTION
STATUS ON
TILEITEM "location"
TYPE POLYGON
UNITS METERS
CLASS
STYLE
COLOR 0 0 0
END # STYLE
END # CLASS
END # LAYER
END # MAP
The same happens when i try to view it using QGIS Tilelayer plugin.
Kind regards,
Mwaura Daniel
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151223/fc5a0f5c/attachment.html>
