[mapserver-users] CGI Tilemode blank on one layer
Daniel Mwaurah mwaurah at gmail.com
Wed Dec 23 13:25:58 PST 2015
Thank you Steve for your response.
I have tried commenting out the extents but still the same problem. I think
it recognizes the inbuilt extents of the data layers.
On Wed, Dec 23, 2015 at 9:36 PM, Lime, Steve D (MNIT) <
Steve.Lime at state.mn.us> wrote:
> What happens if you comment out the layer extents? They really shouldn’t
> be necessary.
> *From:* mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] *On
> Behalf Of *Daniel Mwaurah
> *Sent:* Wednesday, December 23, 2015 2:27 PM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* [mapserver-users] CGI Tilemode blank on one layer
> hallo people,
> I would greatly appreciate some help with Mapserver Tile mode. Eeven a
> hint in the right direction would be much appreciated. I am trying to
> display two layers in Tile mode in open layers as follows
> 1.
> http://localhost/cgi-bin/mapserv?MAP=/var/wpsinput/gdss.map&layer=kenyaoutline&mode=tile&tile=${x}+${y}+${z}.png
> <http://localhost/cgi-bin/mapserv?MAP=/var/wpsinput/gdss.map&layer=kenyaoutline&mode=tile&tile=$%7bx%7d+$%7by%7d+$%7bz%7d.png>
> 2.
> http://localhost/cgi-bin/mapserv?MAP=/var/wpsinput/gdss.map&layer=10m_ocean&mode=tile&tile=${x}+${y}+${z}.png
> <http://localhost/cgi-bin/mapserv?MAP=/var/wpsinput/gdss.map&layer=10m_ocean&mode=tile&tile=$%7bx%7d+$%7by%7d+$%7bz%7d.png>
> The problem arises in that one layer the 10m_ocean displays while the
> other one just shows a blank. I suspect it has to do with the extents
> because the 10m_ocean layers has a large extent from -180 to 180 while the
> kenyaoutline layer only covers one country from about 33 to 37 degrees.
> Is there a limitation to small extents in tile mode? or what could be the
> problem. My mapfile is as below.
> MAP
>   #FONTSET "[fontsetpath]"
> DEBUG 5
>   CONFIG "MS_ERRORFILE" "/var/www/wpsinput/ms_error.txt"
>   EXTENT 33 -5 42 6
>   IMAGETYPE "png"
>   NAME "Natural_Earth_quick_start_for_QGIS"
>   SIZE 600 600
>   CONFIG ON_MISSING_DATA "LOG"
>   STATUS ON
>   UNITS DD
>   OUTPUTFORMAT
>     NAME "png"
>     MIMETYPE "image/png"
>     DRIVER "AGG/PNG"
>     EXTENSION "png"
>     IMAGEMODE RGBA
>     TRANSPARENT TRUE
>   END # OUTPUTFORMAT
>   PROJECTION
>     "proj=longlat"
>     "datum=WGS84"
>     "no_defs"
>   END # PROJECTION
>   LEGEND
>     KEYSIZE 20 10
>     KEYSPACING 5 5
>     LABEL
>       SIZE MEDIUM
>       OFFSET 0 0
>       SHADOWSIZE 1 1
>       TYPE BITMAP
>     END # LABEL
>     STATUS OFF
>   END # LEGEND
>   QUERYMAP
>     SIZE -1 -1
>     STATUS OFF
>     STYLE HILITE
>   END # QUERYMAP
>   SCALEBAR
>     INTERVALS 4
>     LABEL
>       SIZE MEDIUM
>       OFFSET 0 0
>       SHADOWSIZE 1 1
>       TYPE BITMAP
>     END # LABEL
>     SIZE 200 3
>     STATUS OFF
>     UNITS MILES
>   END # SCALEBAR
>   WEB
>     FOOTER ""
>     HEADER ""
>     TEMPPATH ""
>     METADATA
>       "ows_onlineresource"        "
> http://localhost/cgi-bin/mapserv?map=/home/wpsinput/worldmap.map"
>       "ows_enable_request"       "*"
>       "ows_srs"  "EPSG:4326"
>       "ows_title" "Natural_Earth_quick_start_for_QGIS"
>     END # METADATA
>     #TEMPLATE "[templatepath]"
>   END # WEB
>   LAYER
>     DATA "/var/www/10m_physical/10m_ocean.shp"
>     EXTENT 33 -5 42 6
>     METADATA
>       "ows_title" "10m_ocean"
>     END # METADATA
>     NAME "10m_ocean"
>     PROJECTION
>       "proj=longlat"
>       "datum=WGS84"
>       "no_defs"
>     END # PROJECTION
>     STATUS ON
>     TILEITEM "location"
>     TYPE POLYGON
>     UNITS METERS
>     CLASS
>       NAME "Single symbol"
>       STYLE
>         COLOR 198 226 242
>       END # STYLE
>     END # CLASS
>   END # LAYER
> LAYER
>     DATA "/var/www/kenyaoutline/Kenyaoutline.shp"
>     EXTENT 33 -5 42 6
>     METADATA
>       "ows_title" "Kenyaoutline"
>     END # METADATA
>     NAME "Kenyaoutline"
>     PROJECTION
>       "proj=longlat"
>       "datum=WGS84"
>       "no_defs"
>     END # PROJECTION
>     STATUS ON
>     TILEITEM "location"
>     TYPE POLYGON
>     UNITS METERS
>     CLASS
>       STYLE
>         COLOR 0 0 0
>       END # STYLE
>     END # CLASS
>   END # LAYER
> END # MAP
> The same happens when i try to view it using QGIS Tilelayer plugin.
> Kind regards,
> Mwaura Daniel
Kind regards,
Mwaura Daniel
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20151223/baa590ff/attachment.html>
